[GRASS-user] geogrid not smooth in ps.map output
Tyler Smith
tyler at plantarum.ca
Fri Feb 5 11:08:56 PST 2016
I'm making a map for inclusion in a manuscript. I have the basic layout
set, using the wx display system: https://flic.kr/p/CThHdE
Not perfect, but I can tweak the placement of labels in Inkscape.
However, when I try to transfer the code from d.mon to ps.map, the
gridlines become 'jointed', rather than smooth curves:
https://flic.kr/p/DEp7zL
I've tried setting the region resolution, but it doesn't seem to change
anything. How can I plot geographic grids as smooth curves with ps.map?
Or is there a better workflow to accomplish this?
Best,
Tyler
GRASS GIS 7.0.3
d.mon code:
d.vect map=provinces_ca at PERMANENT type=boundary
d.vect map=usa_country at PERMANENT type=boundary
d.vect map=boxes at PERMANENT type=point icon=basic/box fcolor=180:180:180
size=8
d.vect map=triangles at PERMANENT type=point icon=basic/triangle
fcolor=250:250:250 size=9
ps.map input:
# g.region n=2000000 s=-1000000 e=3100000 w=-2550000 res=200
vlines provinces_ca
type boundary
color black
width 0.5
end
vlines usa_country
type boundary
color black
width 0.5
end
geogrid 15 d
color grey
numbers 1 grey
end
vpoints triangles
type point
color black
fcolor 200:200:200
size 4
symbol basic/triangle
width 0.5
end
vpoints boxes
type point
color black
fcolor 100:100:100
size 3
symbol basic/box
width 0.5
end
paper
width 6
height 4
left 0.1
right 0.1
top 0.1
bottom 0.1
end
plantarum.ca
