[GRASS-user] r.terraflow crashes
    Markus Neteler
    neteler at osgeo.org
    Sun Jan  3 15:06:48 PST 2016
On Sun, Jan 3, 2016 at 11:55 PM, Ken Mankoff <mankoff at gmail.com> wrote:
> On 2016-01-03 at 15:46, Anna Petrášová <kratochanna at gmail.com> wrote:
>> I don't have any experience with r.terraflow, but try using
>> r.watershed.
> Crashes with different errors. I'll post about that later. I was using terraflow because it claims to be for large data (not that I think this data is particularly large...)
r.watershed deals quite well with large datasets, too.See
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Large_raster_data_processing
(r.watershed on a 90k x 100k pixels raster map)
> r.mapcalc 'phi = bed*2' does produce a data file, full resolution or downsampled.
> Oddly, "2*bed" works, but "2.5*bed" does not work.
That's rather unusual, indeed.
> Does r.mapcalc only do integer math?
Definitely yes.
> Not according to the manual.
Oh - so we should improve that:
https://grass.osgeo.org/grass70/manuals/r.mapcalc.html
Please let us know where to add extra explanations (what did you look
for and didn't find?)
> "r.info bed" shows the range is -5028 to 3678.
Please note that if "bed" is an integer map, r.mapcalc will generate
integer from "bed * number". You would need to write
2.5 * bed
or
1.0 * bed * 2
to get floating point results.
Should we expand this section?
https://grass.osgeo.org/grass70/manuals/r.mapcalc.html#floating-point-values-in-the-expression
Markus
