[GRASS-user] i.theilsen outputs interpretation
Yann ychemin at gmail.com
Tue Jan 5 14:04:40 PST 2016
Thanks for your sample set (off-list email),
I can replicate the issue,
will look into it.
Yann
On 05/01/2016 14:49, TongXiaoye wrote:
> Dear list,I met a problem in understanding the outputs from i.theilsen module.In order to see the NDVI trend, I use this module to produce a Theil-Sen slope map using 15 years annual summed NDVI maps as inputs.Another output is Mann-Kendall test map. It has values ranging from 1 to 2, which I couldn't link to the theory.I know that theoretically, Kendall's tau values (-1~1) can be used to evaluate trend. A value of +1 indicates  a trend that continuously increases and a value of -1 if it always decrease. A value of 0 indicates no consistent trend.That's what I want to understand from the Mann-Kendall test map.
> Thanks for any help!
> Best,Xiaoye
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
