[GRASS-user] v.external with a postgresql view
patrick s.
patrick_gis at gmx.net
Thu Jan 7 03:48:14 PST 2016
Mary
I had some issues with PG in the past, mainly when one of these was given:
-The data can not have more than one geom-column or GRASS will not know
what to do (NOTE: this is no issue on QGIS, where you select the
geometry manually)
-it might be that you need to define an ID-column that is recognized by
Hope this helps
PAtrick
On 15.12.2015 12:08, grass-user-request at lists.osgeo.org wrote:
> Message: 6
> Date: Tue, 15 Dec 2015 12:03:29 +0100
> From: Maria Elena Martinotti<mariaelena.martinotti at hotmail.it>
> To:"grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] v.external with a postgresql view
> Message-ID:<DUB127-W65F9836AE26A8ADCA77E0C83EE0 at phx.gbl>
> Content-Type: text/plain; charset="iso-8859-1"
> Dear all,
> I have a problem connecting to a PG db with v.external. I created a view on the db (sanfgrass_rain2h) which has a geometry column and grass is able to see it, but when I try to execute v.external it gives me an error about the geometry. See attached lines.
> It seems that the layer is correctly detected but no geometry is imported, even if more tha 3000 points are provided by the view. Moreover I have checked that the view is correctly shown in the geometry_columns view.
> There is an alert concerning the primary key but, AFAIK, it is not possible to define it in a view .
> Thanks for any help,
> Mary
> db.connect driver=pg database="XXX,dbname=YYY,port=5432";
> v.external input="PG:host=XXX user=postgres dbname=YYY" -lt;
> PostGIS database <YYY> contains 64 feature tables:
> anagrafica,point,0,the_geom
> sanfgrass_rain2h,geometry,0,the_geom
> ...v.external input="PG:host=XXX user=postgres dbname=YYY" layer=sanfgrass_rain2h;
> ATTENZIONE: No key column detected.
> ATTENZIONE: Feature table <sanfgrass_rain2h> has no primary key defined.
> Unable to define DB links.
> Si sta ricreando la topologia per il vettore <sanfgrass_rain2h at test_4>...
> Numero di nodi: 0
> Numero di primitive: 0
> Numero di punti: 0
> Numero di linee: 0
> Numero di confini: 0
> Numero di centroidi: 0
> Numero di aree: -
> Numero di isole: -
> v.external completo. Link to vector map <sanfgrass_rain2h> created.
