[GRASS-user] r.out.gdal in GRASS 7.0 beta (windows OS) fails to export merged coloured-shade tiff
Anna Petrášová kratochanna at gmail.com
Wed Jan 13 15:52:27 PST 2016
On Wed, Jan 13, 2016 at 11:50 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Jan 13, 2016 at 3:41 PM, Rengifo Ortega <rengifoo at yahoo.de> wrote:
> > Dear Anna and Christian
> > thanks a lot for yout quick feedbacks.   Attached a link to my dropbox
> > where  I loaded  a pdf that describe shortly what I did and what I get.
> https://www.dropbox.com/s/tt8c1qm229hlnjm/This%20is%20what%20I%20see%20in%20GRASS%207.pdf?dl=0
> You selected "Byte" range but apparently the range is larger than 0..255.
> r.info will tell you, please post it here.
I tried on a raster with similar range of values as you do and when I don't
specify the type it will automatically select UInt16 and I can then open it
in ArcMap without problems and with the colors preserved.
Anna
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160113/1c4e6662/attachment.html>
