[GRASS-user] r.out.gdal in GRASS 7.0 beta (windows OS) fails to export merged coloured-shade tiff
Rengifo Ortega
rengifoo at yahoo.de
Thu Jan 14 01:23:15 PST 2016
Dear Markusthanks a lot. It partly did the trick.
When using those settings in r.out.gdal, as you suggested, it did preserve the colors as you said. But , it also creates a long palette of colors that makes the rendering in ArcGIS very slow specially for large tiffs . On the other hand, the RGB as produced by r.out.tiff (GRASS 6.4) get rendered faster. For the time being it is a vailable solution, specially for small datasets.
For large datasets I am going to stick to r.out.tiff OR a give try to a pure gdal approach using the hsv_merge.py script create by frank warmedam as suggested in this siteA workflow for creating beautiful relief shaded dems using GDAL
| A workflow for creating beautiful relief shaded dems usi...A workflow for creating beautiful relief shaded dems using GDAL Posted December 5, 2010 by Tim Sutton & filed under gdal, General FOSSGIS, Linux and Ubuntu, QGIS. |
| Auf linfiniti.com anzeigen | Vorschau nach Yahoo |
Thanks to everbody who contributed so gently to this discussion.
Best regards
Rengifo Ortega
Markus Neteler <neteler at osgeo.org> schrieb am 1:04 Donnerstag, 14.Januar 2016:
On Jan 14, 2016 12:52 AM, "Anna Petrášová" <kratochanna at gmail.com> wrote:
> I tried on a raster with similar range of values as you do and when I don't specify the type it will automatically select UInt16 and I can then open it in ArcMap without problems and with the colors preserved.This requires, I suppose, GRASS GIS 7.0.1 or later.Markus
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160114/3a474f6a/attachment-0001.html>
