[GRASS-user] V.in.e00 and avcimport
Anna Petrášová
kratochanna at gmail.com
Thu Jan 14 19:14:47 PST 2016
On Thu, Jan 14, 2016 at 9:44 AM, David Stueve <davidstueve at me.com> wrote:
> Hello
> I’m new to GRASS on Mac 10.11 and I believe I have all the required listed
> frameworks.
> I’m trying to import an .E00 file using V.in.e00 and i’m getting the error
> message:
> ERROR: 'avcimport' program not found, install it first
> http://avce00.maptools.org
> I’m not a programer and unsure how to compile the AVCE00 library and then
> where to place it so GRASS will find it. I’ve downloaded Xcode and the
> command line tools but unsure of the next step.
You might try to import that on a Windows machine, avcimport binary is
distributed with winGRASS. If you want to run it on Mac I suggest to look
if there are any building instructions coming with the avcimport code.
Best,
Anna
> Thanks!
> David Stueve
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160114/366fc849/attachment.html>
