[GRASS-user] (re)projection question
Helmut Kudrnovsky hellik at web.de
Thu Jan 21 12:53:02 PST 2016
Ken Mankoff wrote
> Hi Helmut,
> On 2016-01-21 at 11:45, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> a quick internet search finds, e.g.
>> http://geotiff.maptools.org/proj_list/oblique_stereographic.html
>> maybe a starting point.
> I'd found that before, but thank you for sending the link again. I made
> progress on re-reading it.
>> for a correct Proj.4 string to create a location, it's best to ask in the
>> Proj.4 ML.
> The progress I made, unfortunately, makes me unsure if this is a proj4 or
> a grass question. But I'm not sure.
> I don't want to split this thread too much, but decided to try posting on
> GIS.SE since both communities might see it there.
> https://gis.stackexchange.com/questions/177763/how-to-define-proj4-string-for-grass
> I'll post a resolution on this thread if I get an answer there.
on GIS.SE you posted a link to your data; see there:
https://nsidc.org/data/docs/daac/nsidc0092_greenland_ice_thickness.gd.html
" Projection
All grids are in a polar stereographic projection with reference to the
WGS84 ellipsoid. The standard parallel is 71°N, and the projection parallel
(latitude of the center of the projection) is 90°N. The North Pole is the
origin of the projection. The central meridian is 39°W."
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/re-projection-question-tp5246423p5246605.html
Sent from the Grass - Users mailing list archive at Nabble.com.
