[GRASS-user] import of netCDF file into GRASS 7.02
James Maas (MED) J.Maas at uea.ac.uk
Tue Jan 26 09:16:50 PST 2016
I'm attempting to import a netCDF file (filename.nc) into grass.  It is comprised of daily rainfall raster data over 730 days, for a 4 km x 4 km grid.  I think the resolution is 1 km so about 16 points per day.
I've been digging around with gdalinfo and it says the following.
When I use r.in.gdal input=/home/jamaas/research/ra1188uea/Enigma/Rainfall_data/BC_GB_daily.nc output=BC_GB_daily
I get this error
ERROR: Projection of dataset does not appear to match current location.
when I use the -o option I get
Proceeding with import of 0 raster bands...
ERROR: Selected band (1) does not exist
I think I want all of the raster bands, i.e. for all 730 days.  I must be doing something simple incorrectly.
Any suggestions most welcome.
Thanks
J
Driver: netCDF/Network Common Data Format
Files: BC_GB_daily.nc
       BC_GB_daily.nc.aux.xml
Size is 4, 4
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["unknown",
        DATUM["unknown",
            SPHEROID["Spheroid",6377563.396,299.3249646]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",400],
    PARAMETER["false_northing",-100],
    UNIT["kilometre",1000,
        AUTHORITY["EPSG","9036"]]]
Origin = (328.500000000000000,526.500000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
  crs#_CoordinateAxisTypes=GeoX GeoY
  crs#_CoordinateTransformType=Projection
  crs#EPSG_code=EPSG:27700
  crs#false_easting=400
  crs#false_northing=-100
  crs#grid_mapping_name=transverse_mercator
  crs#inverse_flattening=299.3249646
  crs#latitude_of_projection_origin=49
  crs#long_name=coordinate_reference_system
  crs#longitude_of_projection_origin=-2
  crs#scale_factor_at_projection_origin=0.9996012717
  crs#semi_major_axis=6377563.396
  crs#semi_minor_axis=6356256.91
Dr. Jim Maas
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160126/b2836e91/attachment.html>
