[GRASS-user] Reproject a large number of maps + converting to GeoJSON files
Nikos Alexandris
nik at nikosalexandris.net
Fri Jan 29 02:29:20 PST 2016
Panagiotis Mavrogiorgos a écrit:
> Which is the prefered method of reprojecting a large number of maps and
> converting them to e.g. GeoJSON files?
If only a (re-)projection/conversion task, you may rely on gdal/ogr utilities.
> I think that there are two options:
> 1. (According to the wiki
> <https://grasswiki.osgeo.org/wiki/Map_Reprojection>), you should create a
> new location with the export projection you want to export, import the maps
> using {v,r}.proj and then export the maps (e.g. using v.out.ogr/r.out.gdal.
Perhaps it is possible to skip the import part. Using, instead, [rv].external ...?
> 2. Export the maps directly using v.out.ogr/r.out.gdal and then reproject
> them using GDAL/OGR.
> So,
> 1. So are there any significant differences between the two methods? AFAIK
> the underlying algorithms should be the same.
> The first method seems to have higher disk space requirements, while the
> second one seems to be easier to implement.
> 2. How can I handle vertex densification in the second approach?
Reminds of a v.clean related processing. You mean "simplification"?
Not sure if there is an related OGR tool too.
Nikos
> 3. Are there any other caveats that I need to be aware of?
