[GRASS-user] Trouble importing raster dataset
Thomas Adams
tea3rd at gmail.com
Sat Jul 9 17:29:18 PDT 2016
Thank you Markus,
Your suggestions helped to get the data imported into GRASS; but I have the
problem, now, is that the dataset is translated in a N-S about 1.8 deg to
the North. I have tried many things to re-import the data, changing datums,
etc. with the same result. Any other global dataset including from
http://worldclim.org/version2 import and project fine.
Any additional thoughts?
Best,
Tom
On Wed, Jul 6, 2016 at 3:33 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> On Tue, Jul 5, 2016 at 11:36 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> > Here is more info from error from gdalinfo...
> > gdalinfo w001001.adf
> > Coordinate System is:
> > GEOGCS["WGS 84",
> > DATUM["WGS_1984",
> > SPHEROID["WGS 84",6378137,298.257223563,
> > AUTHORITY["EPSG","9108"]],
> > AUTHORITY["EPSG","4326"]]
> > Origin = (-180.000000000000000,90.000007823109627)
> > Pixel Size = (0.008333333767951,-0.008333333767951)
> > Corner Coordinates:
> > Upper Left (-180.0000000, 90.0000078) (180d 0' 0.00"W, 90d 0' 0.03"N)
> ^-- as you can see it exceeds the north pole (> 90.0 degN)
> > Lower Left (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
> > Upper Right ( 180.0000188, 90.0000078) (180d 0' 0.07"E, 90d 0' 0.03"N)
> ... in addition, it exceeds 180W as well. Essentially a broken dataset.
> Solutions:
> https://grass.osgeo.org/grass70/manuals/r.in.gdal.html
> * use flag
> -l Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)
> or see the trick of applying
> gdal_translate -a_ullr ...
> which I added here (the WorldClim data suffer from the same issue):
> https://grass.osgeo.org/grass70/manuals/r.in.gdal.html#worldclim.org-data
> HTH
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160709/886a999b/attachment.html>
