[GRASS-user] UTM 33x
Ken Mankoff
mankoff at gmail.com
Sun Jul 17 05:51:57 PDT 2016
On 2016-07-17 at 12:18, Helmut Kudrnovsky <hellik at web.de> wrote:
> you can define a location by define all needed parameters manually,
> have a look at the GRASS startup wizard
1) grass70 -gui
2) Select GRASS location
3) [new]
4) [Next>]
5) (o) Create a new Cartesian coordinate system (XY)
6) [Next>]
7) [Finish]
8) Do you want to set the default region extents now? [Yes]
9) Set 72,84,9,21 as the S,N,W,E boundaries
10) [Set Region]
GRASS freezes. When I kill the process, terminal prints:
ERROR: Invalid return code from GUI startup script.
Please advise GRASS developers of this error.
Exiting...
> please post the output of g.proj -p
> (https://grass.osgeo.org/grass73/manuals/g.proj.html)
XY location (unprojected)
(that is from =g.proj -p= run in the GRASS location where the GRASS CLI creates the location via the "-c" flag and the file I then import.
> and also post the output of: gdalinfo file.grid
Driver: GS7BG/Golden Software 7 Binary Grid (.grd)
Files: file.grd
Size is 101, 166
Coordinate System is `'
Origin = (509450.000000000000000,8562350.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Corner Coordinates:
Upper Left ( 509450.000, 8562350.000)
Lower Left ( 509450.000, 8545750.000)
Upper Right ( 519550.000, 8562350.000)
Lower Right ( 519550.000, 8545750.000)
Center ( 514500.000, 8554050.000)
Band 1 Block=101x1 Type=Float64, ColorInterp=Undefined
Min=-2.316 Max=385.699
NoData Value=1.70141000000000007e+38
> or try: testepsg file.grid (see attached the file
> gdal_testepsg_espsg_32633.txt
ERROR 1: Error occured translating file.grd.
-k.
