[GRASS-user] Exporting RGB Composite Images to GeoTIFF
Nikos Alexandris
nik at nikosalexandris.net
Fri Jul 22 12:13:45 PDT 2016
* Moritz Lennert <mlennert at club.worldonline.be> [2016-07-22 12:20:17 +0200]:
>>> The addon is not in the addons repository, so you cannot install it with
>>> a simple g.extension i.fusion.hpf. In GRASS 7.2 / trunk you can install
>>> it with g.extension by downloading the source code and pointing the url=
>>> parameter of g.extension to the source code directory.
>>> I hope that the code will be put into the addons repository, soon.
>> from https://grass.osgeo.org/grass72/manuals/g.extension.html
Added.
Nikos
