[GRASS-user] calibration, sensitiviyy analysis tools in GRASS?
Johannes Radinger
johannesradinger at gmail.com
Wed Jul 27 11:47:37 PDT 2016
Dear Vishal,
I am not aware of any GRASS internal modules/add-ons to perform
sensitivity/uncertainty analysis. However, you could try to use R in
combination with GRASS (https://grasswiki.osgeo.org/wiki/R_statistics).
R offers useful packages to perform sampling-based uncertainty analysis of
model parameters e.g. Latin-Hypercube-Sampling (LHS, package 'lhs')
combined with partial rank correlation analysis (PRCC, package
'sensitivity').
I am not exactly sure if this is what you're looking for: First, you could
generate LHS-based parameter combinations for your GRASS groundwater model
and save these parameter combinations into file. Second, this file can be
accessed in a loop within GRASS to repeatedly calculate the groundwater
model for each parameter combination. Third, the results can be collected
and analysed using e.g. PRCC to identify those model parameters which are
most influential on your model result. This is more an R-approach where you
use GRASS just for running your groundwater model. Hope that helps.
Best regards,
Johannes
On Wed, Jul 27, 2016 at 8:11 PM, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> Dear list,
> I'm looking for tools to perform calibration (parameter estimation),
> sensitivity analysis and uncertainty analysis on a groundwater model that i
> built with r.gwflow.
> Does anyone have any pointers, or expertize in this? I see some reference
> to r.ucode in this article:
> Natural Hazards
> <http://link.springer.com.ezproxy.library.tufts.edu/journal/11069>
> January 2014, Volume 70, Issue 2
> <http://link.springer.com.ezproxy.library.tufts.edu/journal/11069/70/2/page/1>,
> pp 1153–1179* "r.massmov*: an open-source landslide model for dynamic
> early warning systems"
> What i'm looking to do is gain insights on a very complex urban
> groundwater problem with data scarcity: for example, the relative
> importance of different sources of uncertainty (hydrogeologic parameters
> versus human influence like pumping and return flows).
> Thanks,
> Vishal
> Vishal K. Mehta, PhD
> Sr. Scientist
> Stockholm Environment Institute - US
> 133 D St Suite F
> Davis CA 95616
> www.sei-us.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160727/1fd3eae3/attachment.html>
