[GRASS-user] R: Problem in deleting a vector map coming from the Vector Digitizer
Aldo CLERICI aldo.clerici at unipr.it
Sat Jun 4 16:29:27 PDT 2016
Rashad,
yes, it should:
(Sun Jun 05 01:23:36 2016)
g.gisenv -n
MAPSET=user1
GISDBASE=C:\Users\Clerici\Documents\grassdata
LOCATION_NAME=Spearfish60_grass7
'GRASS_OVERWRITE=1'
GUI=wxpython
GRASS_OVERWRITE=1
PID=63124
'OVERWRITE=0'
In any case a vector not passed through the Vector Digitizer can be deleted without any problem.
(Sun Jun 05 00:51:43 2016)
g.remove -f type=vector name=roads_copy_4 at user1
Removing vector <roads_copy_4>
(Sun Jun 05 00:51:44 2016) Command finished (0 sec)
Regards,
Aldo
Da: Rashad Kanavath [mailto:mohammedrashadkm at gmail.com]
Inviato: sabato 4 giugno 2016 14:20
A: Aldo CLERICI <aldo.clerici at unipr.it>
Cc: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] Problem in deleting a vector map coming from the Vector Digitizer
On Sat, Jun 4, 2016 at 11:38 AM, Aldo CLERICI <aldo.clerici at unipr.it<mailto:aldo.clerici at unipr.it>> wrote:
Checked with GRASS for Windows 7.0.1,7.0.2,7.0.3, 7.0.4 Stand-alone installer under Windows 7,8,10 with many different PCs.
It seems impossible to delete a map coming from the Vector Digitizer. For example:
1)      I made a copy of roads (Spearfish Location) named roads_copy_3.
2)      I entered the Vector Digitizer with roads_copy_3. I didn’t change anything.
3)      I quitted the Vector Digitizer with the Quit digitizer button.
4)      Trying to delete the map roads_copy_3 I had the following message:
(Sat Jun 04 01:09:24 2016)
g.remove -f type=vector name=roads_copy_3 at user1
Removing vector <roads_copy_3>
WARNING: Unable to delete file 'C:\Users\Clerici\Documents\grassdata/Spearfish60_grass7/user1/vector/roads_copy_3/sidx'
Is this a windows path separator issue?
should be
C:/Users/Clerici/Documents/
WARNING: Unable to delete vector map
WARNING: <roads_copy_3> nothing removed
(Sat Jun 04 01:09:25 2016) Command finished (0 sec)
The cdix, coord, dbln, head, hist component files are lost. Only the sidx and topo remain and no other operation on the vector map (copy, rename) can be done.
I have the same result even with new digitized or with existing modified maps.
Thanks in advance.
Aldo Clerici
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user
Regards,
   Rashad
Il 5xmille a favore dell’Università di Parma (indicando il codice fiscale 00308780345) è un gesto tanto semplice quanto importante per creare nuove opportunità di lavoro per giovani di talento nell'ambito della ricerca scientifica.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160604/2c2e96fb/attachment.html>
