[GRASS-user] v.to.3d for boundary?
    Robert Kuszinger
    kuszinger at giscom.hu
    Mon Jun  6 01:00:57 PDT 2016
Hi all,
I'd like to put a boundary/centroid - into 3D with v.to.3d.
Command:  *v.to.3d --overwrite input=l_00004_buf_diss at Duna
output=l_00004_buf_diss_3d height=110*
*I runs without major erro, however writes this:*
*v.to.3d --overwrite input=l_00004_buf_diss at Duna output=l_00004_buf_diss_3d
height=110WARNING: Vector map <l_00004_buf_diss_3d> already exists and will
be overwrittenTransforming features...Copying attributes...Building
topology for vector map <l_00004_buf_diss_3d at Duna>...Registering
primitives...One primitive registeredOne vertex registeredBuilding
areas...0 areas built0 isles builtAttaching islands...Attaching
centroids...Number of nodes: 0Number of primitives: 1Number of points:
0Number of lines: 0Number of boundaries: 0Number of centroids: 1Number of
areas: 0Number of isles: 0WARNING: Number of centroids exceeds number of
areas: 1 > 0WARNING: Number of centroids outside area: 1Vertical extent of
vector map <l_00004_buf_diss_3d>: B: 110.000000 T: 110.000000*
the original vector map is this:
 | Map format:
native                                                    |
 |   Type of map: vector (level:
2)                                           |
 |   Number of points:       0               Number of centroids:
1          |
 |   Number of lines:        0               Number of boundaries:
198        |
 |   Number of areas:        1               Number of islands:
1          |
 |   Map is 3D:
No                                               |
 |   Number of dblinks:
0                                                |
So, it seems that my area (boundaries) disappear during the conversion...
Topology is correct... what is the problem?
GRASS version info:
GRASS 7.0.3 (2016)
* ./configure  --prefix=/opt/grass
--with-freetype-includes=/usr/include/freetype2 --with-wxwidgets
--with-readline --with-pthread --with-netcdf --with-nls --with-geos
--with-postgres --with-liblaslibgis Revision: 67364 libgis Date: 2015-12-24
16:07:44 +0100 (Thu, 24 Dec 2015) PROJ.4: 4.9.2GDAL/OGR: 2.0.2GEOS:
3.5.0SQLite: 3.12.1*
Thanks
Robert
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160606/e04fb0f2/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160606/e04fb0f2/attachment-0001.jpe>
