[GRASS-user] Exporting to PostGIS - SRID
Martin Landa
landa.martin at gmail.com
Tue Jun 7 02:33:17 PDT 2016
2016-06-07 11:05 GMT+02:00 Micha Silver <micha at arava.co.il>:
> GRASS 7.0.4 (ITM):> g.proj -p
> -PROJ_INFO-------------------------------------------------
> proj : tmerc
> ellps : grs80
> lat_0 : 31.73439361111111
> lon_0 : 35.20451694444445
> k : 1.0000067
> x_0 : 219529.584
> y_0 : 626907.39
> towgs84 : -48,55,52,0,0,0,0
> no_defs : defined
> -PROJ_UNITS------------------------------------------------
> unit : metre
> units : metres
> meters : 1
the EPSG code seems to be missing in your location definition. Please
try to update your settings by running `g.proj -c epsg=`. Then also
make sure that the EPSG code is defined in spatial_ref_sys. It should
work (tested v.out.ogr in 7.0.5svn). Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
