[GRASS-user] Problems with Numpy and matplotlib after updatingthrough OSGeo4W
Veronica Andreo veroandreo at gmail.com
Tue Jun 7 18:06:10 PDT 2016
El jun. 7, 2016 9:33 PM, "Bartolomei.Chris" <Bartolomei.Chris at ensco.com>
escribió:
> If you use msys, then make sure the GRASS_SH variable is set in your
OSGeo4W64/apps/grass/grass-7.0.4/etc/env.bat file (and the GRASS_PYTHON and
PYTHONHOME variables. Here's what I have:
> set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
> set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
> set PYTHONHOME=%OSGEO4W_ROOT%\apps\Python27
Yes, those are exactly my settings... boh
Thanks, Chris
Vero
________________________________________
> From: Veronica Andreo [veroandreo at gmail.com]
> Sent: Tuesday, June 07, 2016 3:12 PM
> To: Bartolomei.Chris
> Cc: grass-user
> Subject: Re: [GRASS-user] Problems with Numpy and matplotlib after
> Hello Chris,
> Thanks much for the answer and follow up :)
> MSYS was already installed in this case and also automatically marked for
"keeping". So, that did not work for me :(
> From my very limited knowledge, I had understood that msys only provided
bash shell for GRASS in Windows. I don't understand how can that be related
to Numpy or matplotlib, but as I said before, I have very limited
knoledge/understanding in that respect.
> Anyway, let's see if somebody else has the same issue or knows how to
solve it... or maybe, it gets automagically fixed in the next update ;)
> Best,
> Vero
> 2016-06-07 16:45 GMT-03:00 Bartolomei.Chris <Bartolomei.Chris at ensco.com
<mailto:Bartolomei.Chris at ensco.com>>:
> I just heard back from my intern and yes, installing msys did solve his
numpy issue ... not sure if that'll help your issue but it worked for him.
> Chris Bartolomei P.E.
> Engineer/Scientist
> ENSCO, Inc.
> bartolomei.chris at ensco.com<mailto:bartolomei.chris at ensco.com>
> From: grass-user [grass-user-bounces at lists.osgeo.org<mailto:
grass-user-bounces at lists.osgeo.org>] On Behalf Of Veronica Andreo [
veroandreo at gmail.com<mailto:veroandreo at gmail.com>]
> Sent: Monday, June 06, 2016 6:44 PM
> To: grass-user
> Subject: [GRASS-user] Problems with Numpy and matplotlib after
> Hi list,
> I just updated grass stable and trunk at my mum and brother's PCs
(windows 7 - 32 bits and windows 10 - 64 bits, respectively) by means of
OSGeo4W installer.
> When starting both versions (7.0.4 and 7.3) in both computers, I get a
message saying Numeric, numarray or NumPy not found.
> Then, when I tried to use g.gui.timeline or g.gui.tplot, I got an error
saying matplotlib and its dependent pyparsing must be installed.
> I run the update again and specifically checked for numpy, matplotlib and
pyparsing under libs, and all of them were there already selected for
update or keep, so dunno...
> Has anybody had a similar issue? Do I have to manually select or install
some other lib/dependency??
> All was fine before the update, in 7.0.3 and 7.1 no such issues in any of
the computers.
> Looking forward to any suggestion :)
> Best,
> Vero
> The information contained in this email message is intended only for the
use of the individual(s) to whom it is addressed and may contain
information that is privileged and sensitive. If you are not the intended
recipient, or otherwise have received this communication in error, please
notify the sender immediately by email at the above referenced address and
note that any further dissemination, distribution or copying of this
communication is strictly prohibited.
> The U.S. Export Control Laws regulate the export and re-export of
technology originating in the United States. This includes the electronic
transmission of information and software to foreign countries and to
certain foreign nationals. Recipient agrees to abide by these laws and
their regulations -- including the U.S. Department of Commerce Export
Administration Regulations and the U.S. Department of State International
Traffic in Arms Regulations -- and not to transfer, by electronic
transmission or otherwise, any content derived from this email to either a
foreign national or a foreign destination in violation of such laws.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160607/ce1d25f3/attachment-0001.html>
