[GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Anna Petrášová kratochanna at gmail.com
Thu Jun 9 13:50:24 PDT 2016
On Thu, Jun 9, 2016 at 4:30 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> yet another GRASS 7.3 64 bit.
> In this version (just uploaded a few minutes ago to the website), I've built
> wxPython from source and installed it in a non-system folder. I built GRASS
> against this local build of wxPython. There should be no problems for SIP if
> it is only the bundled dependencies. And this should not require any
> additional packages like Anaconda.
I tested it on old Yosemite (before SIP came) and works great, but I
was wondering, since you decided to compile wxpython, could you use
wxpython 3.0.3? It's not released, but a lot of bugs are supposed to
be solved there.
Thanks
Anna
> Let me know
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jun 6, 2016, at 12:37 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> OK. This means the /usr/local/... path is hardwired into the wxPython Mac
> binary itself. Not sure if this changes how we need to deal with this.
> Michael
> C. Michael Barton
> On Jun 6, 2016, at 12:15 PM, Adam Dershowitz <adershowitz at exponent.com>
> wrote:
> I just downloaded it, and tried it.  No luck.  It still doesn’t find the
> libraries that it needs:
> '/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Python 2.7.10 found.
> Cleaning up temporary files...
> Starting GRASS GIS...
> Traceback (most recent call last):
>   File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py",
> line 31, in <module>
>     from core import globalvar
>   File
> "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
> line 96, in <module>
>     import wx
>   File
> "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/__init__.py", line
> 45, in <module>
>     from wx._core import *
>   File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py",
> line 4, in <module>
>     import _core_
> ImportError:
> dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so,
> 2): Library not loaded:
> /usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
>   Referenced from:
>   Reason: image not found
> ERROR: Error in GUI startup. See messages above (if any) and if necessary,
> please report this error to the GRASS developers.
> On systems with package manager, make sure you have the right GUI package,
> probably named grass-gui, installed.
> To run GRASS GIS in text mode use the -text flag.
> Exiting...
> logout
> Saving session...
> ...copying shared history...
> ...saving history...truncating history files...
> ...completed.
> Deleting expired sessions...none found.
> [Process completed]
> -- Adam
> From: Michael Barton <Michael.Barton at asu.edu>
> Date: Monday, June 6, 2016 at 2:50 PM
> To: Adam Dershowitz <adershowitz at exponent.com>
> Cc: GRASS developers <grass-dev at lists.osgeo.org>, GRASS users
> <grass-user at lists.osgeo.org>, Helena Mitasova <hmitaso at unity.ncsu.edu>, Anna
> Petrášová <kratochanna at gmail.com>
> Subject: Re: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP
> Adam and others,
> Yet another GRASS 64 bit. I just uploaded to the GRASS for Mac site.
> I tried something else. I am hoping that this works with SIP enabled in El
> Capitan and does not add Anaconda as a required dependency.
> If you have a chance, give it a try.
> Michael
> C. Michael Barton
