[GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Adam Dershowitz adershowitz at exponent.com
Mon Jun 13 06:18:21 PDT 2016
I was traveling last week, so just got to this.
No luck.  And, it doesn’t look like a SIP issue.  Instead, the path is now hard coded to something on your machine.  Here is the error I get when it try to open the application:
$ '/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Cleaning up temporary files...
Starting GRASS GIS...
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
    from core import globalvar
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py", line 96, in <module>
    import wx
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
    import _core_
ImportError: dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /Users/cmbarton/grass_source/wxp3/usr/local/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
  Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so
  Reason: image not found
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting...
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
-- Adam
On 6/9/16, 8:37 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>I've replaced the build from earlier today with one that is sort of wxPython 3.0.3.0
>There was no straightforward way to build this. The only thing on github is the wxpython part. For a full source package it needs to be combined with wxWidgets and both compiled together. The 3.0.2.0 source package has the wxpython folder inside the wxwidgets source folder. Seems easy enough. So I downloaded the latest wxpython and the latest wxwidgets, dropped the wxpython folder inside the wxwidgets folder and compiled. After solving some compiling issues, it all built.
>Then I tried to build GRASS against the result. No problem with the build. But when I went to run it, it had a version mismatch error between wxpython and wxwidgets that disabled 3D.
>So I tried again by replacing the wxpython directory in the 3.0.2.0 source with the new wxpython folder from github. Again, this compiled without problems, and GRASS compiled against it without errors.
>When I run GRASS, it again complains of a version mismatch but it doesn't seem to have any effects. So I've posted this one on the website for now. It does fix the plot.py bug but I can't see any other difference. Maybe you can.
>I'll be very interested to hear if this runs under SIP.
>Cheers
>Michael
>____________________
>C. Michael Barton
>Director, Center for Social Dynamics & Complexity
>Professor of Anthropology, School of Human Evolution & Social Change
>Head, Graduate Faculty in Complex Adaptive Systems Science
>Arizona State University
>voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=ZHG1SBIrTbYkWcpw0RMifv4qtTknor0PcekUo29_faA&s=t-evT5rQyQQdd5Yl-DU1zeDo8ybQZ4me2JzEEZ1ddA4&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=ZHG1SBIrTbYkWcpw0RMifv4qtTknor0PcekUo29_faA&s=xdYPqcLWa0qS3KHYIxFxDSyf5TRG7ewwV8xNHfIrBfI&e=
>> On Jun 9, 2016, at 1:56 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> That's great news. Now to see if it also works under SIP.
>> I wanted to test this to see if it even worked before I tried wxPython 3.0.3 and Glynn's hack for gettext. If it works under El Capitan SIP, then on to the next steps.
>> Michael
>> C. Michael Barton
>>> On Jun 9, 2016, at 1:50 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>> On Thu, Jun 9, 2016 at 4:30 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>> yet another GRASS 7.3 64 bit.
>>>> In this version (just uploaded a few minutes ago to the website), I've built
>>>> wxPython from source and installed it in a non-system folder. I built GRASS
>>>> against this local build of wxPython. There should be no problems for SIP if
>>>> it is only the bundled dependencies. And this should not require any
>>>> additional packages like Anaconda.
>>> I tested it on old Yosemite (before SIP came) and works great, but I
>>> was wondering, since you decided to compile wxpython, could you use
>>> wxpython 3.0.3? It's not released, but a lot of bugs are supposed to
>>> be solved there.
>>> Thanks
>>> Anna
>>>> Let me know
>>>> Michael
>>>> C. Michael Barton
>>>> On Jun 6, 2016, at 12:37 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>> OK. This means the /usr/local/... path is hardwired into the wxPython Mac
>>>> binary itself. Not sure if this changes how we need to deal with this.
>>>> Michael
>>>> C. Michael Barton
>>>> On Jun 6, 2016, at 12:15 PM, Adam Dershowitz <adershowitz at exponent.com>
>>>> wrote:
>>>> I just downloaded it, and tried it.  No luck.  It still doesn’t find the
>>>> libraries that it needs:
>>>> File
>>>>   import wx
>>>> File
>>>> 45, in <module>
>>>> line 4, in <module>
>>>>   import _core_
>>>> ImportError:
>>>> /usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
>>>> Referenced from:
>>>> Exiting...
>>>> logout
>>>> Saving session...
>>>> ...completed.
>>>> Deleting expired sessions...none found.
>>>> [Process completed]
>>>> -- Adam
>>>> From: Michael Barton <Michael.Barton at asu.edu>
>>>> Date: Monday, June 6, 2016 at 2:50 PM
>>>> To: Adam Dershowitz <adershowitz at exponent.com>
>>>> Cc: GRASS developers <grass-dev at lists.osgeo.org>, GRASS users
>>>> <grass-user at lists.osgeo.org>, Helena Mitasova <hmitaso at unity.ncsu.edu>, Anna
>>>> Subject: Re: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP
>>>> Adam and others,
>>>> Yet another GRASS 64 bit. I just uploaded to the GRASS for Mac site.
>>>> I tried something else. I am hoping that this works with SIP enabled in El
>>>> Capitan and does not add Anaconda as a required dependency.
>>>> If you have a chance, give it a try.
>>>> Michael
>>>> C. Michael Barton
