[GRASS-user] Simple example about vector database layers in GRASS
roy roy royroge at outlook.com
Tue Jun 14 00:45:29 PDT 2016
I'm reading this wiki page:
https://grasswiki.osgeo.org/wiki/Vector_Database_Management#The_concept_of_layers
about the GRASS vector model ad the sketch seems to suggest that I can
setup and display
several layer given an available or digitized vetor geometry
In the example I have a vector object (centroid)
id = 16 ( a centroid )
(this id is automatically assigned an internal feature id ... can the id
be diplayed?
how do I know a geometry id?)
joined with two distinct attribute tables via category values, i.e.
16 -> 31  (wheat)
16 -> 26  (a name)
then there is a boundary with id 1:
1 ->  5 (connected to category 5)
what it seems not clear is how you set up such connections:
How do i know what id is assigned to a geometry?
How do i connect "category" to "id" so that I can assign an owner to
each area ?
what does the following phrase from the page means?
"code" value 34 within table "plots" has no corresponding category in
layer 2;
is the term "category" used instead of "id" (quite confusing ...)
is there a list of modules to perform this operation that could help to
better understand?
(eg. use v.category, then use ...)
thanks for any help
