[GRASS-user] Best workflow
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Jun 24 01:17:53 PDT 2016
> From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Paul Meems
Depends on several things, e.g
-        do polygons overlap or not,
-        do “height maps” overlap or not?
-        What are the “several commands” you need to be performed
On the basis of the information you provided I would have a look at
-        gdalbuildvrt for merging your “height map” tiles
-        import PostGIS polygon table to GRASS
-        convert to raster using v.to.rast and assign ID to each raster representation of your polygons
-        calculate statistics using either
o   r.stats
o   r.univar
to create CSV files, which can be read back to PostGIS (COPY command) and then joined to your original map using ID field
I would not consider WCS / GeoServer, that gives you only overhead and extra work...
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160624/5b807619/attachment-0001.html>
