[GRASS-user] GRASS7 crashes on Win10 with large VRT-file.
    Paul Meems
    bontepaarden at gmail.com
    Thu Jun 30 02:15:21 PDT 2016
Hi Markus,
Thanks for confirming the VRT option should work.
I've started a new thread for this issue.
I'm currently running GRASS 7 for Windows on Win10-64Bit.
The 'real' process will run on an Ubuntu server.
g.version -bge returns
version=7.0.4
date=2016
revision=68343
build_date=2016-05-01
build_platform=x86_64-w64-mingw32
 ./configure  --host=x86_64-w64-mingw32
'--with-libs=/c/msys64/usr/src/grass704/mswindows/osgeo4w/lib '
--with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
--prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
--includedir=/c/OSGeo4W64/include --without-x --with-cxx --enable-shared
--enable-largefile --with-fftw --with-freetype
--with-proj-share=/c/OSGeo4W64/share/proj
--with-gdal=/c/msys64/usr/src/grass704/mswindows/osgeo4w/gdal-config
--with-geos=/c/msys64/usr/src/grass704/mswindows/osgeo4w/geos-config
--with-liblas=/c/msys64/usr/src/grass704/mswindows/osgeo4w/liblas-config
--with-sqlite --with-regex --with-nls
--with-freetype-includes=/c/OSGeo4W64/include/freetype2 --with-odbc
--with-cairo --with-postgres --with-opengl=windows
proj4=4.9.2
gdal=2.0.2
geos=3.5.0
sqlite=3.7.17
I also have QGis and MapWindow5 GIS on my machine. Both also use the proj4,
gdal, geos and sqlite libraries. And I run PostgreSQL with PostGIS which is
using GDAL as well.
My tiff-files and my VRT file are on an external USB harddrive.
I created the VRT file using GDAL 1.11.3, released 2015/09/16 because that
version is in my path.
gdalinfo of my VRT is:
Driver: VRT/Virtual Raster
Files: ahn2.vrt
       F:\AHN2\r01cz1.tif
       F:\AHN2\r72hz2.tif
Size is 532000, 600000
Coordinate System is:
PROJCS["Amersfoort / RD New",
    GEOGCS["Amersfoort",
        DATUM["Amersfoort",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000009,
                AUTHORITY["EPSG","7004"]],
TOWGS84[565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725],
            AUTHORITY["EPSG","6289"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4289"]],
    PROJECTION["Oblique_Stereographic"],
    PARAMETER["latitude_of_origin",52.15616055555555],
    PARAMETER["central_meridian",5.38763888888889],
    PARAMETER["scale_factor",0.9999079],
    PARAMETER["false_easting",155000],
    PARAMETER["false_northing",463000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","28992"]]
Origin = (13000.000000000000000,606250.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Corner Coordinates:
Upper Left  (   13000.000,  606250.000) (  3d15' 4.06"E, 53d25'28.87"N)
Lower Left  (   13000.000,  306250.000) (  3d22'34.17"E, 50d43'46.25"N)
Upper Right (  279000.000,  606250.000) (  7d15'12.50"E, 53d25'45.07"N)
Lower Right (  279000.000,  306250.000) (  7d 8'39.35"E, 50d44' 1.23"N)
Center      (  146000.000,  456250.000) (  5d15'22.63"E, 52d 5'43.48"N)
Band 1 Block=128x128 Type=Float32, ColorInterp=Gray
  NoData Value=-3.4028234663852901e+038
To be more precise. I have 1351 tiff-files with a total size of 579 GB.
If needed I could try on another pc with Win10, without QGIS, MW5 and
PostGIS to test if I can open the VRT file using GRASS7.
But eventually I need to combine my PostGIS data because it holds my vector
files.
Thanks,
Paul
2016-06-28 23:04 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Paul,
> On Tue, Jun 28, 2016 at 8:32 AM, Paul Meems <bontepaarden at gmail.com>
> wrote:
> > Thanks Markus for your suggestion.
> > I first tried Stefan's suggestion of using a VRT-file.
> > I have 1300 tiff-files with a combined file size of 400GB. Creating the
> VRT-file was no problem, but when I tried to import the VRT-file in GRASS7
> using r.in.gdal GRASS crashes and dies.
> Huh - should not happen .. But which operating system are you using,
> which GRASS version etc?
> You may post the result of
> g.version -bge
> > Loading the same VRT-file in QGis did take some time to load but it
> worked.
> Please post also the output of
> gdalinfo yourfile.vrt
> > So I think I need to set-up a GeoServer after all, just to get a small
> portion of my height data to process in GRASS without worrying about
> polygons that are partially on multiple tiff-files.
> > Of course I'm open to any other suggestion. As said I'm new to GRASS.
> Let's try harder, data in the your file size range should not be a problem.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160630/6eef9d0b/attachment.html>
