[GRASS-user] How to define the png image dimensions when using d.mon?
jean pierre huart jph at openjph.be
Tue Mar 8 07:28:35 PST 2016
Sorry I've forgotten to precise that I'm using Grass v7.0.3 on ubuntu 14.04.
On 08/03/16 16:15, jean pierre huart wrote:
> Hello,
> I've written a python script to generate an image combining a vector
> map (myvector) and a raster (myraster) that has been generated using a
> mask.
> It works great by default and creates an image with the default
> dimensions 640x480 on a white background.
>         gscript.run_command('d.mon', overwrite=True, start='png',
> output=filename)
>         gscript.run_command('d.rast', map='{0}@{1}'.format(myraster,
> self.mapset))
>         gscript.run_command('d.vect', map='{0}@{1}'.format(myvector,
> self.mapset), color='white', fill_color='none')
>         gscript.run_command('d.mon', stop="png")
> I would like to have a transparent background and to change the
> dimensions of the image to 1280x960.
> Reading the documentation I had the impression that I just have to
> modify some variables, but it does not work.
>         os.environ['GRASS_TRANSPARENT'] = 'TRUE'
>         os.environ['GRASS_WIDTH'] = str(1280)
>         os.environ['GRASS_HEIGHT'] = str(960)
> output=filename)
> self.mapset))
> Thanks in advance for any advice.
> Ciao
Jean Pierre Huart
OpenJph
19, rue de la fontaine
1340 Ottignies
web: www.openjph.be
email: jph at openjph.be
tel:   +32 487 95 77 75
skype: jeanpierre.huart
