[GRASS-user] Compile error
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Wed Mar 9 02:22:18 PST 2016
I can not compile grass-gis from source. I have download grass-gis 7.0.3
source and I have run configure with ./configure
--with-gdal=/usr/local/bin/gdal-config --with-pthread --with-opengl
--with-openmp --with-opencl --with-freetype-includes=/usr/include/freetype2
--with-geos.
When i do make i get this error:
Started compilation: mer 9 mar 2016, 11.16.21, CET
Errors in:
/home/lorenzo/tools/grass-7.0.3/display/d.path
/home/lorenzo/tools/grass-7.0.3/display/d.vect
/home/lorenzo/tools/grass-7.0.3/display/d.vect.chart
/home/lorenzo/tools/grass-7.0.3/display/d.vect.thematic
/home/lorenzo/tools/grass-7.0.3/general/g.copy
/home/lorenzo/tools/grass-7.0.3/general/g.findfile
/home/lorenzo/tools/grass-7.0.3/general/g.list
/home/lorenzo/tools/grass-7.0.3/general/g.region
/home/lorenzo/tools/grass-7.0.3/general/g.remove
/home/lorenzo/tools/grass-7.0.3/general/g.rename
/home/lorenzo/tools/grass-7.0.3/general/manage/lister
/home/lorenzo/tools/grass-7.0.3/raster/r.carve
/home/lorenzo/tools/grass-7.0.3/raster/r.contour
/home/lorenzo/tools/grass-7.0.3/raster/r.cost
/home/lorenzo/tools/grass-7.0.3/raster/r.drain
/home/lorenzo/tools/grass-7.0.3/raster/r.external
/home/lorenzo/tools/grass-7.0.3/raster/r.flow
/home/lorenzo/tools/grass-7.0.3/raster/r.in.gdal
/home/lorenzo/tools/grass-7.0.3/raster/r.out.gdal
/home/lorenzo/tools/grass-7.0.3/raster/r.random
/home/lorenzo/tools/grass-7.0.3/raster/r.reclass
/home/lorenzo/tools/grass-7.0.3/raster/r.region
/home/lorenzo/tools/grass-7.0.3/raster/r.resamp.bspline
/home/lorenzo/tools/grass-7.0.3/raster/r.resamp.rst
/home/lorenzo/tools/grass-7.0.3/raster/r.sim/r.sim.water
/home/lorenzo/tools/grass-7.0.3/raster/r.sim/r.sim.sediment
/home/lorenzo/tools/grass-7.0.3/raster/r.stream.extract
/home/lorenzo/tools/grass-7.0.3/raster/r.to.vect
/home/lorenzo/tools/grass-7.0.3/raster/r.volume
/home/lorenzo/tools/grass-7.0.3/raster/r.walk
/home/lorenzo/tools/grass-7.0.3/raster/r.what
/home/lorenzo/tools/grass-7.0.3/vector/v.buffer
/home/lorenzo/tools/grass-7.0.3/vector/v.build
/home/lorenzo/tools/grass-7.0.3/vector/v.build.polylines
/home/lorenzo/tools/grass-7.0.3/vector/v.category
/home/lorenzo/tools/grass-7.0.3/vector/v.class
/home/lorenzo/tools/grass-7.0.3/vector/v.clean
/home/lorenzo/tools/grass-7.0.3/vector/v.colors
/home/lorenzo/tools/grass-7.0.3/vector/v.colors.out
/home/lorenzo/tools/grass-7.0.3/vector/v.db.connect
/home/lorenzo/tools/grass-7.0.3/vector/v.db.select
/home/lorenzo/tools/grass-7.0.3/vector/v.delaunay
/home/lorenzo/tools/grass-7.0.3/vector/v.distance
/home/lorenzo/tools/grass-7.0.3/vector/v.drape
/home/lorenzo/tools/grass-7.0.3/vector/v.edit
/home/lorenzo/tools/grass-7.0.3/vector/v.extract
/home/lorenzo/tools/grass-7.0.3/vector/v.extrude
/home/lorenzo/tools/grass-7.0.3/vector/v.generalize
/home/lorenzo/tools/grass-7.0.3/vector/v.hull
/home/lorenzo/tools/grass-7.0.3/vector/v.info
/home/lorenzo/tools/grass-7.0.3/vector/v.in.ascii
/home/lorenzo/tools/grass-7.0.3/vector/v.in.db
/home/lorenzo/tools/grass-7.0.3/vector/v.in.dxf
/home/lorenzo/tools/grass-7.0.3/vector/v.in.region
/home/lorenzo/tools/grass-7.0.3/vector/v.kcv
/home/lorenzo/tools/grass-7.0.3/vector/v.kernel
/home/lorenzo/tools/grass-7.0.3/vector/v.label
/home/lorenzo/tools/grass-7.0.3/vector/v.lidar.correction
/home/lorenzo/tools/grass-7.0.3/vector/v.lidar.edgedetection
/home/lorenzo/tools/grass-7.0.3/vector/v.lidar.growing
/home/lorenzo/tools/grass-7.0.3/vector/v.lrs/v.lrs.create
/home/lorenzo/tools/grass-7.0.3/vector/v.lrs/v.lrs.segment
/home/lorenzo/tools/grass-7.0.3/vector/v.lrs/v.lrs.label
/home/lorenzo/tools/grass-7.0.3/vector/v.lrs/v.lrs.where
/home/lorenzo/tools/grass-7.0.3/vector/v.proj
/home/lorenzo/tools/grass-7.0.3/vector/v.mkgrid
/home/lorenzo/tools/grass-7.0.3/vector/v.neighbors
/home/lorenzo/tools/grass-7.0.3/vector/v.net
/home/lorenzo/tools/grass-7.0.3/vector/v.net.alloc
/home/lorenzo/tools/grass-7.0.3/vector/v.net.allpairs
/home/lorenzo/tools/grass-7.0.3/vector/v.net.bridge
/home/lorenzo/tools/grass-7.0.3/vector/v.net.centrality
/home/lorenzo/tools/grass-7.0.3/vector/v.net.components
/home/lorenzo/tools/grass-7.0.3/vector/v.net.connectivity
/home/lorenzo/tools/grass-7.0.3/vector/v.net.distance
/home/lorenzo/tools/grass-7.0.3/vector/v.net.flow
/home/lorenzo/tools/grass-7.0.3/vector/v.net.iso
/home/lorenzo/tools/grass-7.0.3/vector/v.net.path
/home/lorenzo/tools/grass-7.0.3/vector/v.net.salesman
/home/lorenzo/tools/grass-7.0.3/vector/v.net.spanningtree
/home/lorenzo/tools/grass-7.0.3/vector/v.net.steiner
/home/lorenzo/tools/grass-7.0.3/vector/v.net.timetable
/home/lorenzo/tools/grass-7.0.3/vector/v.net.visibility
/home/lorenzo/tools/grass-7.0.3/vector/v.normal
/home/lorenzo/tools/grass-7.0.3/vector/v.out.ascii
/home/lorenzo/tools/grass-7.0.3/vector/v.out.dxf
/home/lorenzo/tools/grass-7.0.3/vector/v.out.pov
/home/lorenzo/tools/grass-7.0.3/vector/v.out.svg
/home/lorenzo/tools/grass-7.0.3/vector/v.out.vtk
/home/lorenzo/tools/grass-7.0.3/vector/v.outlier
/home/lorenzo/tools/grass-7.0.3/vector/v.overlay
/home/lorenzo/tools/grass-7.0.3/vector/v.parallel
/home/lorenzo/tools/grass-7.0.3/vector/v.patch
/home/lorenzo/tools/grass-7.0.3/vector/v.perturb
/home/lorenzo/tools/grass-7.0.3/vector/v.split
/home/lorenzo/tools/grass-7.0.3/vector/v.qcount
/home/lorenzo/tools/grass-7.0.3/vector/v.random
/home/lorenzo/tools/grass-7.0.3/vector/v.reclass
/home/lorenzo/tools/grass-7.0.3/vector/v.rectify
/home/lorenzo/tools/grass-7.0.3/vector/v.sample
/home/lorenzo/tools/grass-7.0.3/vector/v.segment
/home/lorenzo/tools/grass-7.0.3/vector/v.select
/home/lorenzo/tools/grass-7.0.3/vector/v.support
/home/lorenzo/tools/grass-7.0.3/vector/v.surf.bspline
/home/lorenzo/tools/grass-7.0.3/vector/v.surf.idw
/home/lorenzo/tools/grass-7.0.3/vector/v.surf.rst
/home/lorenzo/tools/grass-7.0.3/vector/v.transform
/home/lorenzo/tools/grass-7.0.3/vector/v.to.3d
/home/lorenzo/tools/grass-7.0.3/vector/v.to.db
/home/lorenzo/tools/grass-7.0.3/vector/v.to.points
/home/lorenzo/tools/grass-7.0.3/vector/v.to.rast
/home/lorenzo/tools/grass-7.0.3/vector/v.to.rast3
/home/lorenzo/tools/grass-7.0.3/vector/v.type
/home/lorenzo/tools/grass-7.0.3/vector/v.univar
/home/lorenzo/tools/grass-7.0.3/vector/v.voronoi
/home/lorenzo/tools/grass-7.0.3/vector/v.what
/home/lorenzo/tools/grass-7.0.3/vector/v.what.rast
/home/lorenzo/tools/grass-7.0.3/vector/v.what.rast3
/home/lorenzo/tools/grass-7.0.3/vector/v.vect.stats
/home/lorenzo/tools/grass-7.0.3/vector/v.vol.rst
/home/lorenzo/tools/grass-7.0.3/vector/v.out.ogr
/home/lorenzo/tools/grass-7.0.3/vector/v.in.ogr
/home/lorenzo/tools/grass-7.0.3/vector/v.external
/home/lorenzo/tools/grass-7.0.3/misc/m.nviz.image
/home/lorenzo/tools/grass-7.0.3/misc/m.transform
/home/lorenzo/tools/grass-7.0.3/imagery/i.cca
/home/lorenzo/tools/grass-7.0.3/imagery/i.cluster
/home/lorenzo/tools/grass-7.0.3/imagery/i.gensig
/home/lorenzo/tools/grass-7.0.3/imagery/i.gensigset
/home/lorenzo/tools/grass-7.0.3/imagery/i.group
/home/lorenzo/tools/grass-7.0.3/imagery/i.maxlik
/home/lorenzo/tools/grass-7.0.3/imagery/i.ortho.photo/i.ortho.camera
/home/lorenzo/tools/grass-7.0.3/imagery/i.ortho.photo/i.ortho.elev
/home/lorenzo/tools/grass-7.0.3/imagery/i.ortho.photo/i.ortho.rectify
/home/lorenzo/tools/grass-7.0.3/imagery/i.rectify
/home/lorenzo/tools/grass-7.0.3/imagery/i.segment
/home/lorenzo/tools/grass-7.0.3/imagery/i.smap
/home/lorenzo/tools/grass-7.0.3/imagery/i.target
/home/lorenzo/tools/grass-7.0.3/imagery/i.pca
/home/lorenzo/tools/grass-7.0.3/ps/ps.map
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: mer 9 mar 2016, 11.20.09, CET
make: *** [default] Error 1
How do I fix this?
Tnx,
Lorenzo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160309/ca2316f1/attachment-0001.html>
