[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Adam Dershowitz
adershowitz at exponent.com
Mon Mar 14 19:14:43 PDT 2016
Any luck with this?
I just tried to use 7.0.2 and when it failed, I download and tried 7.0.3, which also failed.
When I try to run it, I see this:
Python 2.7.10 found.
Cleaning up temporary files...
Starting GRASS GIS...
dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.3.dylib
Reason: image not found
And, then as a work around I tried to use the Macports version of that file like this:
install_name_tool -change /usr/local/lib/libintl.8.dylib /opt/local/lib/libintl.8.dylib /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.3.dylib
but instead I now get this error:
adershowitzMBP15:~ adershowitz$ '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
File "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
from core import globalvar
File "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py", line 84, in <module>
import wx
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
from wx._core import *
File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
import _core_
ImportError: dlopen(/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /usr/local/lib/wxPython-unicode-2.8.12.1/lib/libwx_macud-2.8.0.dylib
Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/etc/python/wx/_core_.so
Error in GUI startup. If necessary, please report this error to the GRASS developers.
Switching to text mode now.
Any suggestions or work around would be greatly appreciated. I have some data that I need access to, and usually GRASS is solid and reliable, so not being able to use it is worrisome.
Thanks,
-- Adam
From: grass-user <grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>> on behalf of Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
Date: Monday, February 15, 2016 at 3:24 PM
To: grass-user grass-user <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
The packaging seems to have gone awry. I've been out of the country and then sick since returning. Once I get well enough to get to the office, I'll try and fix this.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=CwMGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=mQkXH1ueNkuN6x_ULoNTVKf8HhzY3BksHkBifuT4ei4&s=hiCFoOIof6xOrTVN-DtaoSCJKiGlG1cbfpgCAh75ATw&e=>, http://csdc.asu.edu<https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=CwMGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=mQkXH1ueNkuN6x_ULoNTVKf8HhzY3BksHkBifuT4ei4&s=LUWEhxCbJLRMSGP1xOrwKsANc9PwKuLL8M8DAqgRa3c&e=>
On Feb 15, 2016, at 12:59 PM, grass-user-request at lists.osgeo.org<mailto:grass-user-request at lists.osgeo.org> wrote:
From: gene <martin.laloux at gmail.com<mailto:martin.laloux at gmail.com>>
Date: February 15, 2016 at 11:55:37 AM MST
To: <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
With the 7.0.3 version of GRASS GIS on the Mac (M.Barton)
<http://grassmac.wikidot.com/<https://urldefense.proofpoint.com/v2/url?u=http-3A__grassmac.wikidot.com_&d=CwMGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=mQkXH1ueNkuN6x_ULoNTVKf8HhzY3BksHkBifuT4ei4&s=noVWFNeapzu4k_YxtrbHFY7wpnxZuLJcx6PEmEIKXrM&e=>> I can only launch GRASS-7.0.app (7.0.3) in
text mode.
When I try to launch the App or use g.gui wxpython in the Grass shell the
error is:
"Launching <wxpython> GUI in the background, please wait…
ERROR: wxGUI requires wxPython. No module named wxversion
In the 7.0.2 version, wxPython is installed in
/Applications/GRASS-7.0.app/Contents/MacOS/etc/python (wx, wxpython and
pyparsing.py and wxversion.py) and it works.
But none of these files/folders exist in the same folder of the 7.0.3
version
Compilation error ?
The size of the zip files are also different (80.19 and 83.89 for GRASS 7.01
and GRASS 7.02, 35 .12 for GRASS 7.03)
Many thanks
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/628e8f1a/attachment-0001.html>
