[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Adam Dershowitz
adershowitz at exponent.com
Tue Mar 15 10:39:43 PDT 2016
I don’t see an option to do that. The portfile has a few variants, but
nothing related to the gui.
-- Adam
On 3/15/16, 12:32 PM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>Adam Dershowitz <adershowitz at exponent.com> writes:
>> I use Macports for a bunch of other things (and Homebrew is
>>incompatible
>> with Macports) So, I figured that I would just tried to install grass7
>> using macports. It does seem to install, but the gui doesn’t work:
>> $grass70
>> Cleaning up temporary files...
>> Starting GRASS GIS...
>> ERROR: wxGUI requires wxPython. No module named wxversion
>> Error in GUI startup. If necessary, please report this error to the
>>GRASS
>> developers.
>> Switching to text mode now.
>I don't use MacPorts - but can you try to install without GUI?
>> Hit RETURN to continue...
>> This is odd, since wxpython is installed.
>> But, it seems like this is a different problem.
>> -- Adam
>> On 3/15/16, 9:50 AM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>>>Michael Barton <Michael.Barton at asu.edu> writes:
>>>> The reason is that I (and William) package some key dependencies with
>>>> the binary. The most important is wxPython, which is required by the
>>>> GUI. If a user does not have exactly the same version of wxPython used
>>>> to compile the binary, the GUI will fail. Making this more complicated
>>>> is the fact that the only versions of wxPython that work completely
>>>> correctly with Mac GRASS are 32 bit. But some other components are 64
>>>> bit. This means that I need to compile GRASS with 32/64 bit dual
>>>> architecture. So this is a consequence of making binaries that run on
>>>> anyone's Mac (except the newest system with SIP enabled).
>>>OK - so if I understand you correctly, installing via homebrew, should
>>>not be that difficult, as GRASS is compiled for a specific wxPython -
>>>correct?
>>>> Michael
>>>> ____________________
>>>> C. Michael Barton
>>>> Director, Center for Social Dynamics & Complexity
>>>> Professor of Anthropology, School of Human Evolution & Social Change
>>>> Head, Graduate Faculty in Complex Adaptive Systems Science
>>>> Arizona State University
>>>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>>>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>>> On Mar 15, 2016, at 3:14 PM, Carlos Grohmann
>>>> <carlos.grohmann at gmail.com> wrote:
>>>> I run GRASS on OSX El Capitan (with SIP disabled). I don't think
>>>> that setting up a CLI-only version would be a solution as well. As
>>>> Rainer said, other software runs natively (see QGIS) and they
>>>> don't have any problems with OSX/SIP. We should look into that.
>>>> I don't understand why GRASS is offending SIP. Perhaps we should
>>>> seek out for help from others. Maybe Apple itself.
>>>> One point is that we need to disable SIP for the binary provided
>>>> by Michael Barton, but not if you compile it from source (or using
>>>> homebrew), so this could be fixable by changing paths, like Adam
>>>> suggested. Homebrew uses /usr/local, why can't we?
>>>> best
>>>> Carlos
>>>> On Tue, Mar 15, 2016 at 9:51 AM, Adam Dershowitz
>>>> <adershowitz at exponent.com> wrote:
>>>> Yes, SIP is a new security feature that prevents any applications
>>>> from
>>>> writing to a few key OS paths. I believe that it really is
>>>> that simple.
>>>> (see: https://support.apple.com/en-us/HT204899 )
>>>> Which, does beg the questionŠwhy does running GRASS require
>>>> writes to any
>>>> of these folders? That suggests that GRASS is doing something
>>>> that it
>>>> shouldn¹t be doing. Why should it be writing to system folders
>>>> at all at
>>>> runtime?
>>>> It is the only application that I have run into that has any
>>>> problems with
>>>> SIP. It would seem that this should be an easy fix. (for
>>>> example just
>>>> use /usr/local instead of /usr, or whatever the problem folder
>>>> is).
>>>> -- Adam
>>>> Prof. Carlos Henrique Grohmann
>>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>>> http://carlosgrohmann.com
>>>> http://orcid.org/0000-0001-5073-5572
>>>> ________________
>>>> Can’t stop the signal.
>>>Rainer M. Krug
>>>email: Rainer<at>krugs<dot>de
>>>PGP: 0x0F52F982
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
>Rainer M. Krug
>PGP: 0x0F52F982
