[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug
Rainer at krugs.de
Wed Mar 16 03:24:15 PDT 2016
Rainer M Krug <Rainer at krugs.de> writes:
> Adam Dershowitz <adershowitz at exponent.com> writes:
>> Got it. Now, based on that, I have found it. Apparently, it is for
>> protected processes:
>> https://developer.apple.com/library/mac/documentation/Security/Conceptual/S
>> ystem_Integrity_Protection_Guide/RuntimeProtections/RuntimeProtections.html
> Which seems to be the reason why during the make step (make is in
> /usr/bin, therefore a protected binary), the DYLD_LIBRARY_PATH is
> ignored.
> But when running GRASS, it should work.
> Has anybody tried out to
> 1) disable SIP
> 2) compile GRASS from source
> 3) install GRASS
> 4) enable SIP
> and does it run?
Just tried it out, ant it works. So the DYLD_LIBRARY_PATH issue only
affects the compilation / installation of GRASS.
> Do you know if Macports uses an own make (and possibly other tools?), or
> the one supplied by OS X?
>> So, would it be possible to just just the paths that are used for the
>> search paths in the Application bundle itself?
>> -- Adam
>> On 3/15/16, 4:43 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
>>>GRASS does not write to those SIP-restricted locations.
>>>From what I've read, SIP also causes apps to ignore DYLD_LIBRARY_PATH, no
>>>matter where it points to. And the errors that have been reported point
>>>to it as well.
>>>> On Mar 15, 2016, at 3:06 PM, Adam Dershowitz <adershowitz at exponent.com>
>>>>wrote:
>>>> On 3/15/16, 3:37 PM, "grass-user on behalf of William Kyngesburye"
>>>> <grass-user-bounces at lists.osgeo.org on behalf of woklist at kyngchaos.com>
>>>> wrote:
>>>>> On Mar 15, 2016, at 2:05 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>>>> William Kyngesburye <woklist at kyngchaos.com> writes:
>>>>>>> This is also a known issue, related to but separate from the
>>>>>>>packaging
>>>>>>> issue. During compilation, GRASS also uses DYLD_LIBRARY_PATH to find
>>>>>>> the in-compilation copies of the libraries so it can run the modules
>>>>>>> to create the help files.
>>>>>> OK - this aligns with what I guessed from the error messages.
>>>>>> So the DYLD_LIBRARY_PATH is only used during compilation - and not
>>>>>> during execution, even without "make install"?
>>>>> No, DYLD_LIBRARY_PATH is also used during execution, that's what's
>>>>> causing trouble in the app bundling.
>>>>>>> The packaging issue with DYLD_LIBRARY_PATH can be fixed in packaging
>>>>>>> so that everything within the GRASS app package looks directly inside
>>>>>>> the package for libraries and not rely on DYLD_LIBRARY_PATH.
>>>>>>> Homebrew, Macports and /usr/local builds don't need to worry about it
>>>>>>> because the extra dependencies that are bundled in the app are
>>>>>>>already
>>>>>>> in their proper place.
>>>>>> OK - so in homebrew (I can't speak for Macports) the issue is at the
>>>>>> moment only the one you discuss below.
>>>>>>> The compilation issue needs work to compile all libraries with the
>>>>>>> temporary path inside the libraries and modules (this part is easy)
>>>>>>>so
>>>>>>> that during compilation help file generation works.
>>>>>> OK - so can you give me any suggestions how I can solve this to make
>>>>>> GRASS at least compile on homebrew?
>>>>>> Speaking generally - is this really the right approach to take, i.e.
>>>>>>use
>>>>>> the generated binaries to generate the help files during installation?
>>>>>> Wouldn't it be much easier to do this during installation?
>>>>> Well, the compilation approach is how it's been done as long as I can
>>>>> remember, it's nothing specific to OS X. Changing this would be major.
>>>>>>> And then during installation change all the embedded library paths to
>>>>>>> the final destination (this is harder, to figure out the complex
>>>>>>> makefile include system of GRASS to get this operation in the right
>>>>>>> place).
>>>>>> The paths are in the grass script file? Or in others as well?
>>>>> No, the paths are embedded in the libraries and binary executables.
>>>>>> Wouldn't it make sense to
>>>>>> 1) split the generation of the help files from the build step into a
>>>>>> separate make target
>>>>>> 2) call the make target for help pages as a last step in the install
>>>>>> step?
>>>>>> This might make packaging more difficult, but wouldn't it make the
>>>>>>whole
>>>>>> process clearer?
>>>>>>> Homebrew, Macports, /usr/local AND app installs do have a problem
>>>>>>>with
>>>>>>> this.
>>>>>> It worked with Yosemite without problems. So this only needs to be
>>>>>>done,
>>>>>> because of the issues you describe above?
>>>>> It's specifically an El Capitan+ issue, because of SIP.
>>>> I wonder if you can explain this anymore. Because, it is not at all
>>>>clear
>>>> to me. DYLD_LIBRARY_PATH is something that is used all the time and
>>>>works
>>>> fine in El Capitan for most Applications. The only thing that SIP
>>>> provides, if I understand correctly, is that it is not possible for an
>>>> application to write to /System /bin /sbin or /usr (and a few Apple
>>>> specifics in /Applications). Writing to /usr/local and /usr/lib should
>>>>be
>>>> OK. Just having all the different versions of libraries around, and
>>>> dynamically finding them should work fine.
>>>> So, during run time, why does GRASS attempt to write to /usr (or one of
>>>> the other Apple owned folders? If it is using DYLD_LIBRARY_PATH to find
>>>> the necessary libraries from within the GRASS bundle, there should be no
>>>> need to write there.
>>>> Is it doing something unusual, such as at startup it tries to copy a few
>>>> files from the bundle to /usr so that it doesn¹t have to change
>>>> DYLD_LIBRARY_PATH? Even if that is the case, just changing those paths
>>>>to
>>>> /usr/local would solve the SIP problem.
>>>> If the problem relates to how GRASS finds the correct version of
>>>> libraries, at least as a work around, it should be possible to use
>>>> install_name_tool to point to the correct version of libraries for any
>>>> specific build. This is what I first attempted, but just fixing one
>>>> library didn¹t do the job for me, as it then triggered another problem.
>>>> So, I really don¹t understand what it is that GRASS does, at runtime,
>>>>that
>>>> SIP objects to.
>>>>>>> It works for Michael (and me) for the "official" packages because we
>>>>>>> compile on older systems that don't have SIP.
>>>>>> Thanks for these clarifications.
>>>>>> I would very much appreciate if we could see to get the compilation
>>>>>>and
>>>>>> installation working using homebrew so that there is at least one way
>>>>>>of
>>>>>> t=running GRASS on El Capitan without having to interfere with the
>>>>>> security settings.
>>>>>> Thanks,
>>>>>> Rainer
>>>>>>>> On Mar 15, 2016, at 11:39 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>>>>>> I tried again to install 7.1 head without GUI using homwbrew, and I
>>>>>>>> get
>>>>>>>> the following error:
>>>>>>>> | bash-4.3$ less
>>>>>>>> /Users/rainerkrug/Library/Logs/Homebrew/grass-71/02.make
>>>>>>>> | bash-4.3$ cd
>>>>>>>> /private/tmp/grass-7120160315-47344-1ybn5ar/scripts/d.rast.leg
>>>>>>>> | bash-4.3$ ls
>>>>>>>> | Makefile d.rast.leg.html d.rast.leg.py
>>>>>>>> | bash-4.3$ make
>>>>>>>> | if [
>>>>>>>>"/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin
>>>>>>>>15
>>>>>>>> .3.0/scripts/d.rast.leg"
>>>>>>>> | != "" ] ; then
>>>>>>>>GISRC=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-d
>>>>>>>>ar
>>>>>>>> win15.3.0/demolocation/.grassrc71
>>>>>>>>GISBASE=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple
>>>>>>>>-d
>>>>>>>> arwin15.3.0
>>>>>>>>PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-d
>>>>>>>>ar
>>>>>>>>win15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64
>>>>>>>>-a
>>>>>>>>pple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dis
>>>>>>>>t.
>>>>>>>> x86_64-apple-darwin15.3.0/scripts:$PATH"
>>>>>>>>PYTHONPATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-a
>>>>>>>>pp
>>>>>>>>le-darwin15.3.0/etc/python:/private/tmp/grass-7120160315-47344-1ybn5a
>>>>>>>>r/
>>>>>>>> dist.x86_64-apple-darwin15.3.0/gui/wxpython:$PYTHONPATH"
>>>>>>>>DYLD_LIBRARY_PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x
>>>>>>>>86
>>>>>>>>_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5a
>>>>>>>>r/
>>>>>>>>dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-4734
>>>>>>>>4-
>>>>>>>>1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:/private/tmp/grass-712
>>>>>>>>01
>>>>>>>>60315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:/private/tmp/g
>>>>>>>>ra
>>>>>>>> ss-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:"
>>>>>>>> | LC_ALL=C
>>>>>>>>/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin1
>>>>>>>>5.
>>>>>>>> | --html-description < /dev/null | grep -v '</body>\|</html>' >
>>>>>>>> | d.rast.leg.tmp.html ; fi
>>>>>>>> | dyld: Library not loaded:
>>>>>>>>/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.sv
>>>>>>>>n.
>>>>>>>> dylib
>>>>>>>> | Referenced from:
>>>>>>>>5.
>>>>>>>> 3.0/bin/g.parser
>>>>>>>> | Reason: image not found
>>>>>>>> | make: *** [d.rast.leg.tmp.html] Error 1
>>>>>>>> | rm d.rast.leg.tmp.html
>>>>>>>> | bash-4.3$
>>>>>>>> In other words: grass is looking during the compilation for a
>>>>>>>>dynamic
>>>>>>>> library
>>>>>>>>(/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.s
>>>>>>>>vn
>>>>>>>> .dylib)
>>>>>>>> which has been created, but will only be there when installing.
>>>>>>>> Also important: this error only occurs when the html manual pages
>>>>>>>>are
>>>>>>>> created!
>>>>>>>> Cheers,
>>>>>>>> Rainer
>>>>>>>>>> I use Macports for a bunch of other things (and Homebrew is
>>>>>>>>>> incompatible
>>>>>>>>>> with Macports) So, I figured that I would just tried to install
>>>>>>>>>> grass7
>>>>>>>>>> using macports. It does seem to install, but the gui doesn¹t
>>>>>>>>>>work:
>>>>>>>>>> $grass70
>>>>>>>>>> Cleaning up temporary files...
>>>>>>>>>> Starting GRASS GIS...
>>>>>>>>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>>>>>>>>> Error in GUI startup. If necessary, please report this error to
>>>>>>>>>>the
>>>>>>>>>> GRASS
>>>>>>>>>> developers.
>>>>>>>>>> Switching to text mode now.
>>>>>>>>> I don't use MacPorts - but can you try to install without GUI?
>>>>>>>>>> Hit RETURN to continue...
>>>>>>>>>> This is odd, since wxpython is installed.
>>>>>>>>>> But, it seems like this is a different problem.
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.kyngchaos.com_&d
>>>>>=C
>>>>>wIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rC
>>>>>n8
>>>>>wM&m=r1HkNs7RjOpSnmLwmP3Cs2L1e3PUB46Ip-W1bup-rFc&s=4w5wYepEPeebD54T1h_V7
>>>>>mJ
>>>>> Bf8t6V3mbREBfgUP8u90&e=
>>>>> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
>>>>> that remind me of? Ah, yes - life."
>>>>> - Marvin
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mail
>>>>>ma
>>>>>n_listinfo_grass-2Duser&d=CwIGaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabR
>>>>>Lt
>>>>>SzGmh8YEvbco28TaiOmWcn6rCn8wM&m=r1HkNs7RjOpSnmLwmP3Cs2L1e3PUB46Ip-W1bup-
>>>>>rF
>>>>> c&s=Wvr4pv5ar3OjaTpiOn-UaLvVb2_IFgxGgKN0IHHRSXo&e=
>>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mailm
>>>>an_listinfo_grass-2Duser&d=CwIFaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabR
>>>>LtSzGmh8YEvbco28TaiOmWcn6rCn8wM&m=wBZVhJR1Vijar8vPd0vMw-5LMplYPnRZhF_TOf4
>>>>CZvY&s=dFMvzAURv7ExJqKWuHhJuiWSp1tVxWAQLXdLERfRUcY&e=
>>>https://urldefense.proofpoint.com/v2/url?u=http-3A__www.kyngchaos.com_&d=C
>>>wIFaQ&c=t0wRGL5ICVzH157W8C8Wew&r=5usL3OGqXabRLtSzGmh8YEvbco28TaiOmWcn6rCn8
>>>wM&m=wBZVhJR1Vijar8vPd0vMw-5LMplYPnRZhF_TOf4CZvY&s=GvawdpD6TkYdZwsdpwjWw1t
>>>6syI0zj0Ou2szNtTSNWQ&e=
>>>"I ache, therefore I am. Or in my case - I am, therefore I ache."
>>>- Marvin
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160316/eb3f83eb/attachment.sig>
