[GRASS-user] How to define the png image dimensions when using d.mon?
Glynn Clements
glynn at gclements.plus.com
Sat Mar 26 10:52:06 PDT 2016
Martin Landa wrote:
> > d.mon is designed for interactive use. If you're writing a script,
> > don't use it. Set GRASS_RENDER_IMMEDIATE=png (or =cairo) and use the
> > environment variables.
> not really, beside wx monitors, you can use cairo or png (useful for
> scripting). Martin
You appear to be misunderstanding what "interactive" means in this
context. It doesn't necessarily imply a GUI.
The only situation where a script should be using d.mon is if it
really is a "script", in the sense of a canned sequence of commands
which is meant to be "replayed" as part of an interactive workflow.
Anything which tries to behave like a typical program should manage
the relevant environment variables directly.
