[GRASS-user] Use of d.rast3d_wrapper (GRASS 7.0.3 for Windows)
Anna Petrášová
kratochanna at gmail.com
Mon Mar 28 05:38:04 PDT 2016
On Mon, Mar 28, 2016 at 6:54 AM, Aldo CLERICI <aldo.clerici at unipr.it> wrote:
> Dear GRASS users,
> I don’t understand the panel “Add various raster map layers RGB, HIS…)” >
> “Add 3D raster map layer”. What is it for? Should it display a 3D map in the
> Map Display or simply list the map name in the Layer Manager? Is there some
> manual page explaining the d.rast3d command?
> Many thanks in advance.
You have to add 3D raster to layer manager first to be able to
visualize it in 3D view using isosurfaces or slices.
Anna
> A. Clerici
> Il 5xmille a favore dell’Università di Parma (indicando il codice fiscale
> 00308780345) è un gesto tanto semplice quanto importante per creare nuove
> opportunità di lavoro per giovani di talento nell'ambito della ricerca
> scientifica.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
