[GRASS-user] FW: Temporal + export
Markus Neteler
neteler at osgeo.org
Thu May 5 09:39:08 PDT 2016
Hi Matías,
On Thu, May 5, 2016 at 5:41 PM, Matías Alejandro Castillo Moine
<matialecastillo at hotmail.com> wrote:
> Hi everyone!
> I never used a list... I think I made a mistake when sent the message
> yesterday...
now it reached the list :)
> I was construct a strds in grass 7.0.3,
(Would it be possible for you to update to 7.0.4? Just to be sure that
the problem is yes/no solved?
> and I want to export it for use in R
> to do some statistics not included with tgrass.. But when I do the export
> operation, I receive this message:
> Usising the GUI:
> t.rast.export --overwrite --verbose input=LST2 at MOD11A2 output=C:\SIG\Base de
> datos area de estudio\Datasets_R\LSR_R compression=gzip
Hint: You are using white space in the path ("Base de datos area de
estudio\"). Maybe it doesn't matter but just to exclude this potential
issue, please try with a different path name.
> new_cwd = tempfile.mkdtemp(dir=directory)
> File "C:\OSGEO4~1\apps\Python27\lib\tempfile.py", line
> 329, in mkdtemp
> _os.mkdir(file, 0700)
> WindowsError: [Error 3] El sistema no puede encontrar la
> ruta especificada: '/tmp\\tmppi2oh1'
This looks like a bug: it uses /tmp/ which does not exist on Windows.
The current code is:
/lib/python/temporal/stds_export.py, line 274
# Create the temporary directory and jump into it
os.chdir(new_cwd)
but AFAIK it should use this portable function:
lib/python/script/core.py:def tempdir():
@devs: opinions?
Concerning the other issue:
> In python (very difficult):
> input="LST2 at MOD11A2"
> output="LST_R.tar.gz"
> compression="gzip"
> directory="C:/SIG/Base de datos area de estudio/Datasets_R/"
> where=None
> format_="GTiff"
> type_="strds"
> tgis.export_stds(input, output, compression, directory, where, format_,
> type_)
>>>>Traceback (most recent call last):
> File "<input>", line 1, in <module>
> File
> "C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\temporal\stds_export.py",
> line 298, in export_stds
> rows, tar, list_file, new_cwd, fs, format_)
> File
> line 74, in _export_raster_maps_as_gdal
> nodata = max_val + 1
> TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
...here I have no suggestion. Anyone?
Markus
