[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio
carlo.cormio at gmail.com
Fri May 6 09:37:33 PDT 2016
MMMh, maybe I'm making a mess ...
I "make distclean" my GRASS GIS build, updated svn (svn up) to r68383,
then compiled and make, but it says it's r68381.
Do I have to make something different to compile and install the righr
revision?!
Thanks,
Carlo
Il 06/05/2016 16:57, Markus Neteler ha scritto:
> On 5/6/16, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> 2016-05-06 15:59 GMT+02:00 Carlo Cormio <carlo.cormio at gmail.com>:
>>> ALso XML Copy Editor analysis provides the same error message:
>>> Error at line 17, column 26: not well-formed (invalid token)
>> it seems to be here:
>> <gisprompt age=""old" element="cell" prompt="raster";" />
>> the correct form is:
>> <gisprompt age="old" element="cell" prompt="raster" />
> Fixed in r68382. Two wrong ";" chars removed (I suppose a leftover
> from the related C syntax while this is Python).
> Carlo, please try again.
> Markus
