[GRASS-user] r.to.vect.lines addon not working
Carlo Cormio carlo.cormio at gmail.com
Sun May 8 11:49:07 PDT 2016
Works perfectly :-)
Thank you very much Anna, Markus, Martin.
Carlo
Il 07/05/2016 13:39, Anna Petrášová ha scritto:
> On Sat, May 7, 2016 at 5:04 AM, Carlo Cormio <carlo.cormio at gmail.com> wrote:
>> Hi Anna,
>> Il 06/05/2016 20:19, Anna Petrášová ha scritto:
>>> Try g.extension again, I hopefully fixed it.
>>> Anna
>> Interface appears now, but there's a new error message:
>> Traceback (most recent call last):
>>    File
>> "/home/ccormio/.grass7/addons/scripts/r.to.vect.lines", line
>> 191, in <module>
>>      main()
>>    File
>> 96, in main
>>      data_type = Rast_get_map_type(inmap, mapset)
>> NameError: global name 'Rast_get_map_type' is not defined
>> Carlo
> Please, try again. The addon was apparently not ported to GRASS 7.
> Anna
