[GRASS-user] PostgreSQL not in v.out.ogr format options
Moritz Lennert mlennert at club.worldonline.be
Wed May 11 23:34:40 PDT 2016
On 11/05/16 20:55, Peter Tittmann wrote:
> Moritz,
> I am on OS X and have installed gala and grass using home-brew.
> v.in.ogr  -f results do not include PostgreSQL
> Any suggestions?
Sounds like GRASS is using a different gdal installation than ogr2ogr...
I am no expert on Mac installation, so others will have to help you with
this.
Rainer, do you have any advice ?
Moritz
> Sorry for the delay getting back…
> Peter
>> On Apr 30, 2016, at 5:55 AM, Moritz Lennert <mlennert at club.worldonline.be> wrote:
>> [Please keep discussions on the list]
>> On 29/04/16 19:35, Peter Tittmann wrote:
>>> Thx  for your reply!
>>>    -> "PostgreSQL" (read/write)
>> And
>> v.in.ogr -f | grep PostgreSQL
>> If that doesn't show success, then it would seem to me that there might be an issue in your installation with GRASS not picking up the correct ogr libraries.
>> On what OS are you ?
>> Moritz
>>>> On Apr 29, 2016, at 10:27 AM, Moritz Lennert
>>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>>>> wrote:
>>>> On 29/04/16 18:00, Peter Tittmann wrote:
>>>>> All,
>>>>> Using GRASS7. I would like to write to postgis from a GRASS vector file,
>>>>> and would like to be able to append to a table as opposed to create new.
>>>>> I see that the `-a` flag is not implemented yet in v.out.postgis so I
>>>>> turned to v.out.ogr. Despite having a fully functional GDAL with the OGR
>>>>> PostgreSQL driver installed and functional, when I pass the following
>>>>> command:
>>>>> `v.out.ogr -a -m --verbose input=t_lands type=area
>>>>> output="PG:dbname=cf_tribal" output_layer=foo format=PostgreSQL`
>>>>> the response is:
>>>>> `ERROR: Value <PostgreSQL> out of range for parameter <format>
>>>>> Legal range:
>>>>> BNA,CSV,CartoDB,Cloudant,CouchDB,DGN,DXF,ESRI_Shapefile,ElasticSearch,GFT,GME,GML,GPKG,GPSBabel,GPSTrackMaker,GPX,GeoJSON,GeoRSS,Geoconcept,JML,KML,MapInfo_File,Memory,ODS,OGR_GMT,PCIDSK,PDF,PGDUMP,S57,SQLite,Selafin,TIGER,WAsP,XLSX`
>>>> What does
>>>> ogrinfo --formats | grep PostgreSQL
>>>> give you ?
>>>> Moritz
