[GRASS-user] problems running v.centroids
Bartolomei.Chris
Bartolomei.Chris at ensco.com
Thu May 12 11:14:44 PDT 2016
I'm not sure if this is it but looking at the path to the "os.py" my installation (although OSGEO4W and 7.0.4) shows "Lib" not "lib" ...
It it is having trouble finding the os.py file, then the difference in the spelling of lib with a capital letter may be the issue...
Could it be that simple ?!?!
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris at ensco.com
________________________________________
From: grass-user [grass-user-bounces at lists.osgeo.org] On Behalf Of Uwe Fischer [gisfisch at t-online.de]
Sent: Thursday, May 12, 2016 8:48 AM
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] problems running v.centroids
Hello List,
I can’t get >v.centroids< working in Grass 7.0.3.
When I try I get the following message:
v.centroids --overwrite --quiet input=inputmap output=outputmap cat=1000
File "C:\PROGRA~1\QGISES~1\apps\grass\grass-7.0.3/scripts/v.centroids.py", line 69, in <module> main()
File "C:\PROGRA~1\QGISES~1\apps\grass\grass-7.0.3/scripts/v.centroids.py", line 63, in main
grass.exec_command("v.category", type = 'area',**options)
File "C:\PROGRA~1\QGISES~1\apps\grass\grass-7.0.3\etc\python\grass\script\core.py", line 536, in exec_command
os.execvpe(prog, args, env)
File "C:\PROGRA~1\QGISES~1\apps\Python27\lib\os.py", line 353, in execvpe
_execvpe(file, args, env)
File "C:\PROGRA~1\QGISES~1\apps\Python27\lib\os.py", line 380, in _execvpe
func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
(Wed May 11 08:00:49 2016) Command finished (0 sec)
I have no idea what that means and where to look for the error.
Furthermore, the final goal is to run v.centroids as part of an external python script that can be started from outside GRASS.
When I try this, I get the following message:
Process ended with non-zero return code 1. See errors in the (error) output.
What ist the "(error) output" of a python script and where can I find it?
best regards,
Uwe Fischer
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
