[GRASS-user] Build a layer from points
Markus Neteler
neteler at osgeo.org
Thu May 12 12:18:01 PDT 2016
Hi Alec,
On Sat, Mar 26, 2016 at 8:27 PM, Alec Ventura <alecventura at hotmail.com> wrote:
> Hello folks, I am trying to create a layer, similar with a gross elevation
> map, it will have some different altitudes.
> I tried to use v.to.rast3 command and it runs without error, but nothing
> happens.
> Am I using the right command?
what are you aiming at? a volume (the the direction is right) or a
common 2D elevation map with height values as pixel values?
Maybe take a look at
https://grasswiki.osgeo.org/wiki/Contour_lines_to_DEM
which refers to contour lines but some of the methods explained there
are similar for point data.
Markus
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
