[GRASS-user] [GRASS-dev] Added i.landsat8.swlst in grass-addons
Nikos Alexandris nik at nikosalexandris.net
Sun May 15 01:58:43 PDT 2016
* Blumentrath, Stefan <Stefan.Blumentrath at nina.no> [2016-05-14 21:21:25 +0000]:
>Hei Nikos (and others),
H(e)i :-)
On my way to understand how to work as, what you described, an educated
programmer (more than half-way through a series of excellent courses,
Rice University).
To this end, I try to build good programming habits:  clean
and extensively commented code, modularity (assisting re-usability) and
tests, tests and tests.  And of course, (algorithm-ic) efficiency (read
input size vs. running time).
That's why I use a lot of helper functions, instead of "lambda" functions.
>Actually, on a second thought, I am considering to change the module
>significantly. Maybe better to just generate a file with
>reclassification rules for all possible combination of bitpattern?
>That would simplify the module (only the filter criteria are required
>as input), and the resulting r.reclass rules can be applied to any
>landsat scene... So they can be generated once and then reused.
>That would be more efficient if several scenes should be processed with
>the same procedure.
Decreasing the final running time, yes.  Another option, in such a case
of multiple scenes, might be to cache the rules in question, after the
first loop (?).
>However users would have to run r.reclass themselfs
>in a next step... But that is probably more in line with the modular
>concept of GRASS...
>What do you think /prefer?
I'll have more time next month and, I think, I can contribute in this
discussion.  I am sorry if this isn't of great help at the moment.
I started implementing the idea of a dedicated Landsat8 python class
(for GRASS, of course):
https://github.com/NikosAlexandris/landsat8_metadata.
One of the To Do points is "Implement mechanism to translate QA pixel
values to QA bits, and vice versa?".
It would be wonderful to have feedback from higher level experts in the
list.
Warmest Regards, Nikos
