[GRASS-user] i.segment.stats memory usage error
James Duffy
james.philip.duffy at gmail.com
Wed Nov 2 03:05:46 PDT 2016
I can't register with osgeo to submit a bug as no-one has replied with a
'mantra' for me to do so... what a convoluted bug reporting system!
And in your opinion Moritz, does it look like my workflow will not be
possible unless I find a 64bit machine with a decent amount of RAM?
Thanks for your support on this.
James
On 27 October 2016 at 20:47, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Le Thu, 27 Oct 2016 20:33:23 +0100,
> James Duffy <james.philip.duffy at gmail.com> a écrit :
> > On 27 October 2016 at 17:48, Moritz Lennert
> > <mlennert at club.worldonline.be> wrote:
> > > > Running:
> > > > r.univar -et gp_ortho.1 zones=gp_seg_optimum_clump
> > > > output=testoutput2.csv
> > > > Returns:
> > > > Current region rows: 12627, cols: 23991
> > > > ERROR: G_realloc: unable to allocate 224000 bytes of memory at
> > > > raster/r.univar/r.univar_main.c:324
> > > Ok, so the issue is with r.univar (although the issue has made me
> > > aware that i.segment.stats could be made way more memory efficient
> > > as well).
> > > How much RAM do you have on your machine ?
> > It's a virtual machine which I have dedicated about 10GB.
> > > This warrants a bug report. Would you be willing to file one on
> > > http://trac.osgeo.org/grass ?
> > I'm happy to submit it if you can guide me as to what exactly should
> > go into it please?
> The bug report should concentrate on r.univar
> You should provide:
> - region settings (output of g.region -p)
> - info about the two maps going into the command, i.e. r.info, plus the
> info that the segment map is an output of r.clump and thus
> sequentially numbered
> - the error message
> I don't know how difficult it will be to allow for lower memory usage
> in r.univar, so we'll have to see if an improvement is possible.
> Moritz
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161102/a74d5aed/attachment-0001.html>
