[GRASS-user] i.segment.stats memory usage error
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Nov  4 07:51:11 PDT 2016
On 04/11/16 12:24, James Duffy wrote:
> Moritz, have you seen the reply on the bug rep?
> https://trac.osgeo.org/grass/ticket/3197
> <https://trac.osgeo.org/grass/ticket/3197>
> Do you think the alternative r.univar2 could be used in your function?
Yes, I saw the answer. As Pietro said, r.univar2 was not ported to
grass7 and I don't have time for that now. I also don't really know why
the module is faster, but ideally the changes should be merged into
r.univar instead of creating a second, similar module.
Two years ago, we had an exchange about this [1], but there was no
follow-up.
@Pietro: could you maybe explain how you changed the logic to see how
difficult it would be to integrate this into r.univar ?
Moritz
[1] https://lists.osgeo.org/pipermail/grass-dev/2014-January/066823.html
