[GRASS-user] problem creating secant Lambert Conformal Conic projection
    Patton, Eric (NRCan/RNCan)
    eric.patton at canada.ca
    Tue Nov 15 11:10:39 PST 2016
Markus,
Responding to a months-old post (sorry!)
Upgrading to proj 4.9.2 and gdal 2.1.2 seemed to fix the problem.
Both secant parallels in my Lambert Conformal projection are now being reported:
> g.proj -we
PROJCS["Lambert_Conformal_Conic",
    GEOGCS["GCS_WGS_1984",
        DATUM["D_WGS_1984",
            SPHEROID["WGS_1984",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Lambert_Conformal_Conic"],
    PARAMETER["standard_parallel_1",65],
    PARAMETER["standard_parallel_2",75],
    PARAMETER["latitude_of_origin",65],
    PARAMETER["central_meridian",-60],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
Sorry for the noise!
Eric
________________________________________
From: neteler.osgeo at gmail.com <neteler.osgeo at gmail.com> on behalf of Markus Neteler <neteler at osgeo.org>
Sent: Tuesday, May 17, 2016 5:33 PM
To: Patton, Eric (NRCan/RNCan)
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] problem creating secant Lambert Conformal Conic projection
On Tue, May 17, 2016 at 7:28 PM, Patton, Eric (NRCan/RNCan)
<eric.patton at canada.ca> wrote:
> Hi Markus,
> Sorry for the delay in responding. I am using Grass 7.0.5svn, proj 4.8.0,
> gdal 1.10.1.
> I really don’t understand what could be the cause of this. I tried a fresh
> checkout and install, and encountered the same behavior. I'm using the proj
> and gdal packages provided by my package manager, so there's no custom
> installations installed in parallel.
proj-4.8.0 is from roughly 13-Mar-2012
I use proj 4.9.1, 04 March 2015
Perhaps some fixes in between?
Markus
