[GRASS-user] 3D Grid
Anna Petrášová kratochanna at gmail.com
Wed Nov 16 05:59:14 PST 2016
On Wed, Nov 16, 2016 at 8:34 AM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi,
> I want to permanently display the grey x/y/z (3D grid) in a 3D view (it
> actually appears briefly when you apply any movement tool) in the 3D view. I
> can use a constant surface and a transparency value but it's not as useful
> as a grid you can adjust the resolution of.
> Is there a way to do it in either 7.3svn or 7.0.5?
Hi, not sure if I understand you correctly, but if you create a raster
with single value, you can then visualize it in 3D  with style coarse
as wire frame.
Anna
> Thanks,
> Paul J. Shapley MSc CGeog (GIS) FRGS
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
