[GRASS-user] v.net.iso - segmentation fault error
    Eduardo Corbelle Rico
    eduardo.corbelle at gmx.net
    Wed Nov 16 10:14:23 PST 2016
O Mér, 16-11-2016 ás 15:22 +0100, Markus Metz escribiu:
> On Wed, Nov 16, 2016 at 11:44 AM, Eduardo Corbelle Rico <eduardo.corb
> elle at gmx.net> wrote:
> > O Xov, 27-10-2016 ás 14:56 +0200, Markus Metz escribiu:
> > > On Thu, Oct 27, 2016 at 11:16 AM, Eduardo Corbelle Rico
> > > <eduardo.corbelle at gmx.net> wrote:
> > > > O Mér, 26-10-2016 ás 23:18 +0200, Markus Metz escribiu:
> > > > > On Thu, Oct 13, 2016 at 9:55 AM, Eduardo Corbelle Rico
> > > > > > Dear all,
> > > > > > I am unable to use v.net.iso because of a "segmentation
> fault"
> > > > > > error. I
> > > > > >  have a script that used to work correctly in GRASS 6.4 (32
> > > > > > bit)
> > > > > > but
> > > > > > produces this error after I switched to GRASS 7.0.4 (64
> bit).
> > > > > > If I try to follow both examples shown in https://grass.osg
> eo.o
> > > > > > rg/g
> > > > > > rass
> > > > > > 70/manuals/v.net.iso.html (using the Spearfish dataset for
> > > > > > GRASS 7)
> > > > > > the
> > > > > > same error appears:
> > > > > > > Building graph...
> > > > > > > Registering arcs...
> > > > > > > Segmentation fault
> > > > > The segmentation fault must happen in the vector libraries. I
> > > > > tested
> > > > > on Linux and can not reproduce the segmentation fault.
> Valgrind
> > > > > also
> > > > > does not show anything that could cause a segmentation fault.
> Can
> > > > > you
> > > > > provide a gdb backtrace?
> > > > > Markus M
> > > > Thank you Markus,
> > > > My system is debian Stretch, and the following lines describe
> my
> > > > attempt at generating a gdb backtrace. Please let me know if I
> > > > should
> > > > do otherwise.
> > > So far so good. The module crashes in a library function that
> comes
> > > from libavl without modifications, but I can still not see why it
> > > could cause a segmentation fault. Can you recompile with the
> compiler
> > > debugging option -g? gdb will then be able to provide more
> > > information:
> > > make distclean
> > > CFLAGS="-g" ./configure <configure options>
> > > make
> > > optionally make install
> > > Then start GRASS and use gdb for v.net.iso as before.
> > > Markus M
> > Dear Markus,
> > Following those instructions does not seem to have changed the
> > resulting backtrace info (copied below). Maybe I missed something
> along
> > the way?
> Is this something Debian specific that debugging symbols must be
> explicitly activated? Are you using GCC or another compiler?
> Alternatively, you can also try valgrind:
> CMD="v.net.iso input=myroads_net output=myroads_net_iso
> center_cats=1-100000 costs=1000,2000,5000 --o"
> valgrind --tool=memcheck --log-file=v.net.iso.vg.log $CMD
> Markus M
You were right: it was my fault not having grass-core-dbgsym and grass-
dev-dbgsym packages installed. I copied below the results of the
debugging commands:
GRASS 7.0.5 (spearfish60_grass7):~ > gdb `which v.net.iso`
GNU gdb (Debian 7.11.1-2+b1) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl
.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show
copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/lib/grass70/bin/v.net.iso...Reading symbols
from /usr/lib/debug/.build-
id/5a/060fc6c3da41153d82601e3fa37ba6d88e9c6c.debug...done.
done.
(gdb) run input=myroads_net output=myroads_net_iso center_cats=1-100000
Starting program: /usr/lib/grass70/bin/v.net.iso input=myroads_net
output=myroads_net_iso center_cats=1-100000 costs=1000,2000,5000
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-
gnu/libthread_db.so.1".
Building graph...
Registering arcs...
Program received signal SIGSEGV, Segmentation fault.
tavl_probe (tree=tree at entry=0x55555599b6c0, item=item at entry=0x55555599f
7b0)
    at tavl.c:146
146	tavl.c: Non hai tal ficheiro ou directorio.
(gdb) bt full
#0  tavl_probe (tree=tree at entry=0x55555599b6c0, item=item at entry=0x55555
599f7b0)
    at tavl.c:146
        y = 0x0
        z = 0x55555599b6c0
        p = 0x0
        q = <optimized out>
        n = 0x55555599f7d0
        w = <optimized out>
        dir = <optimized out>
        da =
"\023\000\000\000\000\000\000\000\000\vb\367\377\177\000\000\300\266\23
1UUU\000\000\030\000\000\000\000\000\000"
        k = 0
        __PRETTY_FUNCTION__ = "tavl_probe"
#1  0x00007ffff6c65717 in dglTreeNodeAdd (pavl=0x55555599b6c0,
    nKey=nKey at entry=1) at tree.c:73
        pnode = 0x55555599f7b0
        ppvret = <optimized out>
#2  0x00007ffff6c5aa0c in dgl_add_edge_V1 (pgraph=0x7fffffffd078,
    nHead=<optimized out>, nTail=<optimized out>, nCost=1231014,
nEdge=1,
    pvHeadAttr=pvHeadAttr at entry=0x0, pvTailAttr=0x0, pvEdgeAttr=0x0,
nFlags=0)
    at edgemgmt-template.c:59
        pHead = <optimized out>
        pTail = <optimized out>
        pEdgeset = <optimized out>
        pEdge = <optimized out>
        pHeadNodeItem = <optimized out>
        pTailNodeItem = <optimized out>
#3  0x00007ffff6c58a62 in dglAddEdge (pGraph=pGraph at entry=0x7fffffffd07
8,
    nHead=<optimized out>, nTail=<optimized out>, nCost=<optimized
out>,
    nEdge=nEdge at entry=1) at graph.c:624
        nRet = <optimized out>
#4  0x00007ffff7ba1d69 in Vect_net_build_graph (Map=0x7fffffffcca0,
    ltype=<optimized out>, afield=1, nfield=2, afcol=0x0, abcol=0x0,
ncol=0x0,
    geo=0, version=1) at net.c:303
        i = 1
        j = <optimized out>
        from = 1
        to = 2
        line = <optimized out>
        nlines = <optimized out>
        nnodes = <optimized out>
        type = <optimized out>
        cat = 48
        skipped = 0
        cfound = <optimized out>
        dofw = <optimized out>
        dobw = 1
        Points = <optimized out>
        Cats = 0x5555557602f0
        dcost = 1231.0148500818718
        bdcost = 1231.0148500818718
        ll = <optimized out>
        cost = 1231014
        bcost = 0
        gr = 0x7fffffffd078
        dgl_cost = 0
        opaqueset = {360000, 0 <repeats 15 times>}
        Fi = <optimized out>
        driver = <optimized out>
        handle = {dbName = {string = 0x0, nalloc = 0}, dbSchema = {
            string = 0x0, nalloc = 0}}
        stmt = {string = 0x0, nalloc = 0}
        Column = 0x0
        fvarr = {n_values = -13424, alloc = 32767, ctype = -148152984,
          value = 0x53455f0043}
        bvarr = {n_values = 0, alloc = 0, ctype = -148153640,
          value = 0x415353454d5f434c}
        fctype = <optimized out>
        bctype = <optimized out>
        nrec = <optimized out>
#5  0x0000555555555b08 in main (argc=<optimized out>, argv=<optimized
out>)
    at main.c:190
        i = <optimized out>
        centre = <optimized out>
        centre1 = <optimized out>
        centre2 = <optimized out>
        type = 6
        ltype = <optimized out>
        geo = 0
        cat = 32767
        node = <optimized out>
        node1 = -13264
        node2 = 32767
        cost = -nan(0xfefbd28e20000)
        e1cost = 6.9533475197415044e-310
        e2cost = 6.9533490679313337e-310
        n1cost = 6.9531436082559572e-310
        n2cost = 6.953349164098692e-310
        s1cost = <optimized out>
        s2cost = <optimized out>
        l = <optimized out>
        l1 = <optimized out>
        map = 0x7ffff7b67888 <state+136>
        output = 0x555555790a10
        afield_opt = <optimized out>
        nfield_opt = <optimized out>
        afcol = 0x555555790cd0
        abcol = 0x555555790d70
        ncol = 0x555555790e10
        type_opt = <optimized out>
        term_opt = <optimized out>
        cost_opt = <optimized out>
        geo_f = 0x7ffff7b67858 <state+88>
        module = <optimized out>
        Map = {format = 0, temporary = 0, dblnk = 0x5555557919b0, plus
            version = {topo = {major = 5, minor = 1, back_major = 5,
                back_minor = 1}, spidx = {major = 5, minor = 1,
                back_major = 5, back_minor = 1}, cidx = {major = 5,
minor = 0,
                back_major = 5, back_minor = 0}}, with_z = 0,
            spidx_with_z = 0, off_t_size = 4, head_size = 142,
            spidx_head_size = 113, cidx_head_size = 9, release_support
= 0,
            port = {byte_order = 0, off_t_size = 0,
              dbl_cnvrt = "\000\001\002\003\004\005\006\a",
              flt_cnvrt = "\000\001\002\003", lng_cnvrt =
"\000\001\002\003",
              int_cnvrt = "\000\001\002\003", shrt_cnvrt = "\000\001",
              off_t_cnvrt = "\000\001\002\003\004\005\006\a", dbl_quick
= 1,
              flt_quick = 1, lng_quick = 1, int_quick = 1, shrt_quick =
1,
              off_t_quick = 1}, spidx_port = {byte_order = 0,
off_t_size = 4,
"\000\001\002\003",
= 1,
1,
              off_t_quick = 1}, cidx_port = {byte_order = 0, off_t_size
= 0,
"\000\001\002\003",
= 1,
1,
              off_t_quick = 1}, mode = 0, built = 4, box = {
              N = 4928063.3980146097, S = 4914006.3378370199,
              E = 609527.21021496004, W = 589434.85646865005, T = 0, B
= 0},
            Node = 0x555555797d50, Line = 0x5555557aa880,
            Area = 0x5555557b9150, Isle = 0x5555557b9170, n_plines =
1,
            n_llines = 827, n_blines = 0, n_clines = 0, n_flines = 0,
            n_klines = 0, n_vfaces = 0, n_hfaces = 0, n_nodes = 678,
            n_edges = 0, n_lines = 828, n_areas = 0, n_isles = 0,
n_faces = 0,
            n_volumes = 0, n_holes = 0, alloc_nodes = 678, alloc_edges
= 0,
            alloc_lines = 828, alloc_areas = 0, alloc_isles = 0,
            alloc_faces = 0, alloc_volumes = 0, alloc_holes = 0,
            Node_offset = 142, Edge_offset = 0, Line_offset = 26934,
            Area_offset = 37690, Isle_offset = 37690, Volume_offset =
0,
            Hole_offset = 0, Spidx_built = 1, Spidx_new = 0, Spidx_file
= 1,
            spidx_fp = {file = 0x555555796d40, start = 0x0, current =
0x0,
              end = 0x0, size = 0, alloc = 0, loaded = 0},
            Node_spidx_offset = 61041, Line_spidx_offset = 131013,
            Area_spidx_offset = 131489, Isle_spidx_offset = 131965,
            Face_spidx_offset = 0, Volume_spidx_offset = 0,
            Hole_spidx_offset = 0, Node_spidx = 0x555555792880,
            Line_spidx = 0x55555582e8a0, Area_spidx = 0x5555558a7d80,
            Isle_spidx = 0x555555921260, Face_spidx = 0x0, Volume_spidx
= 0x0,
            Hole_spidx = 0x0, update_cidx = 0, n_cidx = 2, a_cidx = 5,
            cidx = 0x555555795d70, cidx_up_to_date = 1, coor_size =
101723,
            coor_mtime = 0, uplist = {do_uplist = 0, uplines = 0x0,
              uplines_offset = 0x0, alloc_uplines = 0, n_uplines = 0,
              upnodes = 0x0, alloc_upnodes = 0, n_upnodes = 0}},
          open = 1428335138, mode = 0, level = 2, head_only = 0,
          support_updated = 0, name = 0x555555760170 "myroads_net",
          mapset = 0x555555760470 "user1",
          location = 0x555555760530 "spearfish60_grass7",
          gisdbase = 0x5555557605f0 "/home/eduardo/GRASSDATA",
next_line = 1,
          constraint = {region_flag = 0, box = {N = 0, S = 0, E = 0, W
= 0,
              T = 0, B = 0}, type_flag = 0, type = 0, field_flag = 0,
            field = 0}, proj = 0, hist_fp = 0x55555599f010, dgraph = {
            line_type = 6, graph_s = {iErrno = 0, Version = 1 '\001',
              Endian = 1 '\001', NodeAttrSize = 0, EdgeAttrSize = 0,
              aOpaqueSet = {360000, 0 <repeats 15 times>}, cNode = 0,
              cHead = 0, cTail = 0, cAlone = 0, cEdge = 0, nnCost = 0,
              Flags = 0, nFamily = 0, nOptions = 0,
              pNodeTree = 0x55555599b6c0, pEdgeTree = 0x0, pNodeBuffer
= 0x0,
              iNodeBuffer = 0, pEdgeBuffer = 0x0, iEdgeBuffer = 0,
              edgePrioritizer = {cEdge = 0, iEdge = 0, pEdgePri32Item =
0x0,
                pvAVL = 0x0}, nodePrioritizer = {pvAVL = 0x0}}, spCache
              nStartNode = 0, NodeHeap = {index = 0, count = 0, block =
0,
                pnode = 0x0}, pvVisited = 0x0, pvPredist = 0x0},
            edge_fcosts = 0x5555559a0490, edge_bcosts =
0x5555559a1e80,
            node_costs = 0x5555559a3870, cost_multip = 1000}, head = {
            organization = 0x555555795a50 "US Army Const. Eng. Rsch.
Lab",
            date = 0x555555760770 "5/26/90",
            user_name = 0x555555760850 "youngs",
            map_name = 0x555555760910 "Output from Vpatch",
            source_date = 0x5555557606b0 "1961", orig_scale = 24000,
            comment = 0x555555796d00 "new roads at 1:24000 for
Spearfish database", proj = 1, plani_zone = 13, digit_thresh = 18.288,
coor_version = {
              major = 5, minor = 1, back_major = 5, back_minor = 1},
            with_z = 0, size = 101723, head_size = 18, port =
{byte_order = 0,
              off_t_size = 0, dbl_cnvrt =
"\000\001\002\003",
= 1,
1,
              off_t_quick = 1}, last_offset = 18, recycle = 0x0},
dig_fp = {
            file = 0x55555599b700, start = 0x0, current = 0x0, end =
0x0,
            size = 0, alloc = 0, loaded = 0}, fInfo = {i = 0, ogr = {
              driver_name = 0x0, dsn = 0x0, layer_name = 0x0, driver =
0x0,
              ds = 0x0, layer = 0x0, dbdriver = 0x0, dsn_options =
0x0,
              layer_options = 0x0, cache = {lines = 0x0, lines_types =
0x0,
                lines_cats = 0x0, lines_alloc = 0, lines_num = 0,
                lines_next = 0, fid = 0, sf_type = SF_GEOMETRY, ctype =
0},
              feature_cache = 0x0, offset = {array = 0x0, array_num =
0,
                array_alloc = 0}, next_line = 0}, pg = {conninfo =
0x0,
              db_name = 0x0, schema_name = 0x0, table_name = 0x0,
              fid_column = 0x0, geom_column = 0x0, feature_type =
SF_GEOMETRY,
              coor_dim = 0, srid = 0, dbdriver = 0x0, fi = 0x0,
              inTransaction = 0, conn = 0x0, res = 0x0, cursor_name =
0x0,
              cursor_fid = 0, next_line = 0, cache = {lines = 0x0,
                lines_types = 0x0, lines_cats = 0x0, lines_alloc = 0,
                lines_num = 0, lines_next = 0, fid = 0, sf_type =
SF_GEOMETRY,
                ctype = 0}, offset = {array = 0x0, array_num = 0,
                array_alloc = 0}, topogeom_column = 0x0,
              toposchema_name = 0x0, toposchema_id = 0, topo_geo_only =
0}},
          site_att = 0x0, n_site_att = 0, n_site_dbl = 0, n_site_str =
0}
        Out = {format = -1478492160, temporary = -1,
          dblnk = 0xffffefbd28e20000, plus = {version = {topo = {
                major = -165154152, minor = 32767, back_major =
-136416591,
                back_minor = 32767}, spidx = {major = 1, minor =
32767,
                back_major = -134430384, back_minor = 32767}, cidx = {
                major = -11776, minor = 32767, back_major = 685899776,
                back_minor = -4163}}, with_z = -161323944,
            spidx_with_z = 32767, off_t_size = -136417169,
            head_size = 140733193388033, spidx_head_size =
140737353923672,
            cidx_head_size = 140737488344240, release_support =
685899776,
            port = {byte_order = -4163, off_t_size = -161323992,
              dbl_cnvrt = "\377\177\000\000op\336", <incomplete
sequence \367>, flt_cnvrt = "\377\177\000", lng_cnvrt =
"\001\000\000",
              int_cnvrt = "\377\177\000",
              shrt_cnvrt = "\330", <incomplete sequence \331>,
              off_t_cnvrt = "\377\367\377\177\000\000\340", <incomplete
sequence \324>, dbl_quick = 32767, flt_quick = 685899776, lng_quick =
-4163,
              int_quick = -141390440, shrt_quick = 32767,
              off_t_quick = -136417169}, spidx_port = {byte_order =
32767,
              off_t_size = 1,
              dbl_cnvrt = "\377\177\000\000\000\265\374", <incomplete
"\020\325\377\377",
              int_cnvrt = "\377\177\000", shrt_cnvrt = "\000",
              off_t_cnvrt = "\342(\275\357\377\377pb", dbl_quick =
32767,
              flt_quick = -136417169, lng_quick = 32767, int_quick =
1,
              shrt_quick = 32767, off_t_quick = -134434816}, cidx_port
              byte_order = 32767, off_t_size = -10944,
              dbl_cnvrt = "\377\177\000\000\000\000\342(",
              flt_cnvrt = "\275\357\377\377",
              lng_cnvrt = "`b\266", <incomplete sequence \367>,
              int_cnvrt = "\377\177\000", shrt_cnvrt = "op",
              off_t_cnvrt = "\336\367\377\177\000\000\001", dbl_quick =
32767,
              flt_quick = -134420240, lng_quick = 32767, int_quick =
-10896,
              shrt_quick = 32767, off_t_quick = 685899776}, mode =
-4163,
            built = -136480704, box = {N = 6.9533490679313337e-310,
              S = 6.9531436082559572e-310, E = 6.9533491665290997e-
310,
              W = 6.9533558072990419e-310, T = -nan(0xfefbd28e20000),
              B = 6.9533490647914972e-310},
            Node = 0x7ffff7de706f <_dl_map_object_deps+607>,
            Line = 0x7fff00000001, Area = 0x7ffff7fcdee0,
            Isle = 0x7fffffffd5d0, n_plines = 685899776, n_llines =
-4163,
            n_blines = -136480736, n_clines = 32767, n_flines =
-136417169,
            n_klines = 32767, n_vfaces = 1, n_hfaces = 32767,
            n_nodes = -134424112, n_edges = 32767, n_lines = -10752,
            n_areas = 32767, n_isles = 685899776, n_faces = -4163,
            n_volumes = -136480752, n_holes = 32767, alloc_nodes =
-136417169,
            alloc_edges = 32767, alloc_lines = 1, alloc_areas = 32767,
            alloc_isles = -134425368, alloc_faces = 32767,
            alloc_volumes = -10704, alloc_holes = 32767,
            Node_offset = -17879262953472, Edge_offset =
140737351874544,
            Line_offset = 140737351938159, Area_offset =
140733193388033,
            Isle_offset = 140737353928704, Volume_offset =
140737488344672,
            Hole_offset = -17879262953472, Spidx_built = -136480800,
            Spidx_new = 32767, Spidx_file = -136417169, spidx_fp = {
              file = 0x7fff00000001, start = 0x7ffff7fd0930 "",
              current = 0x7fffffffd690 "\001",
              end = 0x7ffff7de3114 <check_match+324>
"\205\300\017\205m\377\377\377\351z\377\377\377\017\037\200", size =
140737351874512, alloc = 302,
              loaded = -134545704}, Node_spidx_offset =
140736985276032,
            Line_spidx_offset = 140736985286208,
            Area_spidx_offset = 140737351924051, Isle_spidx_offset =
302,
            Face_spidx_offset = 140736985286208,
            Volume_spidx_offset = 140737353809624,
            Hole_spidx_offset = 140737488345016, Node_spidx =
0x7fffffffd7b4,
            Line_spidx = 0xffffefbd28e20000, Area_spidx =
0x7fffe203c70d,
            Isle_spidx = 0x7fffe203bad0, Face_spidx = 0x7fffffffd7b8,
            Volume_spidx = 0x97a26e6c, Hole_spidx = 0x25e89b9,
            update_cidx = -503069120, n_cidx = 32767, a_cidx = -10096,
            cidx = 0x7fffe2039e80, cidx_up_to_date = -10316,
            coor_size = 140737488345216, coor_mtime = 140737353776784,
            uplist = {do_uplist = -136433388, uplines = 0xf7dd7780,
              uplines_offset = 0x197, alloc_uplines = -134253520,
              n_uplines = 32767, upnodes = 0x7ffff728bd90,
              alloc_upnodes = -148271048, n_upnodes = 32767}},
          open = -136433388, mode = 32767, level = 407, head_only = 0,
          support_updated = -136433388, name = 0x7ffff7fcbc58 "",
          mapset = 0x83a <error: Cannot access memory at address
0x83a>,
          location = 0x7ffff7ff7430 "", gisdbase = 0x7ffff728bd90 "",
          next_line = -148271048, constraint = {region_flag =
-136431277,
            box = {N = 1.0405022501416652e-320, S =
6.9533484822718954e-310,
              E = 6.9533491748297978e-310, W = 6.9533558073381719e-
310,
              T = 6.9533558073379743e-310, B = 6.9533490671516982e-
310},
            type_flag = -201603917, type = 32767, field_flag =
-201740488,
            field = 32767}, proj = -10056, hist_fp = 0x1c93965e, dgraph
            line_type = 7491161, graph_s = {iErrno = -136433388,
              Version = 255 '\377', Endian = 127 '\177',
              NodeAttrSize = 140737488345488, EdgeAttrSize = 990,
              aOpaqueSet = {140737354101808, 140737340030352,
140737340084280,
                140737351924051, 990, 140737340084280,
140737354101808,
                140737488345416, 140737488345412, 140737351922379,
                140737278937163, 140737278684160, 140737488345416,
2822930839,
                44108294, 140737340084280}, cNode = 140737488345632,
              cHead = 140737340030352, cTail = 140737488345412,
              cAlone = 140737488345616, cEdge = 140737353776784, nnCost
= 120,
              Flags = 4294957648, nFamily = 7426, nOptions =
4160538376,
              pNodeTree = 0x0, pEdgeTree = 0x7ffff383b200,
              pNodeBuffer = 0x7ffff7fcca60 " \344\377\367\377\177",
              iNodeBuffer = 140737488345776,
              pEdgeBuffer = 0x7ffff7fa5fd8 "\256\266\215\363\377\177",
              iEdgeBuffer = 0, edgePrioritizer = {cEdge = -136433388,
                iEdge = 32767, pEdgePri32Item = 0x7ffff72bb040
<__restore_rt>,
                pvAVL = 0xa50}, nodePrioritizer = {pvAVL =
0x7ffff7fcbc58}},
            spCache = {nStartNode = 140737286612536, NodeHeap = {
                index = 140737286745064, count = 140737351924051,
                block = 2640, pnode = 0x7ffff3fbabe8},
              pvVisited = 0x7ffff7fcbc58, pvPredist = 0x7fffffffda58},
            edge_fcosts = 0x7fffffffda54,
            edge_bcosts = 0x7ffff7de32cb <do_lookup_x+347>,
            node_costs = 0x7ffff387b022, cost_multip = -209671024},
head = {
            organization = 0x7fffffffda58 "",
            date = 0x4cd4b8c7 <error: Cannot access memory at address
0x4cd4b8c7>, user_name = 0x13352e3 <error: Cannot access memory at
address 0x13352e3>,
            map_name = 0x7ffff3fbabe8 "",
            source_date = 0x7fffffffdb30 "\270\235\372\363\377\177",
            orig_scale = 140737286612536, comment = 0x7fffffffda54 "",
            proj = -9440, plani_zone = 32767,
            digit_thresh = 6.9533491587714785e-310, coor_version = {
              major = 120, minor = 0, back_major = -9320, back_minor =
0},
            with_z = -136429983, size = 23, head_size = 0, port = {
              byte_order = 1, off_t_size = 0,
              dbl_cnvrt = "`\312\374\367\377\177\000",
              flt_cnvrt = "\300\333\377\377", lng_cnvrt =
"\377\177\000",
              int_cnvrt = "\250_\372", <incomplete sequence \367>,
              shrt_cnvrt = "\377\177",
              off_t_cnvrt = "\000\000\001\000\000\000\000", dbl_quick =
0,
              flt_quick = 0, lng_quick = -9240, int_quick = 32767,
              shrt_quick = -136429983, off_t_quick = 32767},
last_offset = 21,
            recycle = 0x7ffff7fa5fa8}, dig_fp = {file = 0x1, start =
0x0,
            current = 0x1 <error: Cannot access memory at address
0x1>,
            end = 0x7ffff7fcc708 "", size = 0, alloc = 0, loaded = 0},
          fInfo = {i = -134428064, ogr = {
              driver_name = 0x7fffffffdb30 "\270\235\372\363\377\177",
              dsn = 0x100000000 <error: Cannot access memory at address
0x100000000>, layer_name = 0x7ffff7fcc708 "", driver = 0x7fffffffdb20,
              ds = 0x7ffff387b022, layer = 0x4cd4b8c7, dbdriver =
0xffffffff,
              dsn_options = 0x0, layer_options = 0x7ffff3fa9db8, cache
                lines = 0x7ffff7fcbc58, lines_types = 0x0,
                lines_cats = 0x28206e6f10000000, lines_alloc =
1952531488,
                lines_num = 1396982881, lines_next = 1145315372,
                fid = 140737280262720, sf_type = 8, ctype = 0},
              feature_cache = 0x1, offset = {array = 0x0, array_num =
-9320,
                array_alloc = 32767}, next_line = -136429983}, pg = {
              conninfo = 0x17 <error: Cannot access memory at address
0x17>,
              db_name = 0x7ffff3d74a60 "\300\024\003\364\377\177",
              schema_name = 0x7fffffffdda8 "v\341\377\377\377\177",
              table_name = 0x7fffffffddd8 "\350\341\377\377\377\177",
              fid_column = 0x7ffff3d38ef0 "pa\227\363\377\177",
              geom_column = 0x0, feature_type = SF_MULTILINESTRING,
              coor_dim = 0, srid = -136410668, dbdriver = 0x1, fi =
0x0,
              inTransaction = -204239120, conn = 0x7ffff3fa9db8,
              res = 0x7fffffffdd00,
              cursor_name = 0x7ffff7df006f
<_dl_runtime_resolve_sse+159> "I\211\303f\017\032\234$\260", cursor_fid
                lines_types = 0x0, lines_cats = 0x40, lines_alloc =
1040,
                lines_num = 0, lines_next = 64, fid = 1040, sf_type =
1088,
                ctype = 0}, offset = {array = 0x10, array_num = 66,
                array_alloc = 64},
              topogeom_column = 0x2 <error: Cannot access memory at
address 0x2>, toposchema_name = 0x0, toposchema_id = 93, topo_geo_only
= 110}},
119}
        catlist = 0x555555791380
        Centers = 0x0
        acentres = 0
        ncentres = 0
        Nodes = <optimized out>
        Cats = 0x55555575efc0
        Points = 0x555555791020
        SPoints = 0x555555791350
        niso = <optimized out>
        aiso = <optimized out>
        iso = 0x5555557913b0
        npnts1 = <optimized out>
        apnts1 = 0
        npnts2 = <optimized out>
        apnts2 = 0
        pnts1 = 0x0
        pnts2 = 0x0
        next_iso = <optimized out>
(gdb) bt full
599f7b0)
    at tavl.c:146
        y = 0x0
        z = 0x55555599b6c0
        p = 0x0
        q = <optimized out>
        n = 0x55555599f7d0
        w = <optimized out>
        da =
        k = 0
nEdge=1,
nFlags=0)
8,
out>,
ncol=0x0,
        i = 1
        j = <optimized out>
        from = 1
        to = 2
        cat = 48
        skipped = 0
        dobw = 1
        cost = 1231014
        bcost = 0
        gr = 0x7fffffffd078
        dgl_cost = 0
        Column = 0x0
out>)
    at main.c:190
        i = <optimized out>
        type = 6
        geo = 0
        cat = 32767
        node1 = -13264
        node2 = 32767
        l = <optimized out>
minor = 0,
= 0,
"\000\001\002\003",
= 1,
1,
off_t_size = 4,
"\000\001\002\003",
= 1,
1,
= 0,
"\000\001\002\003",
= 1,
1,
= 0},
1,
n_faces = 0,
= 0,
0,
= 1,
0x0,
= 0x0,
101723,
next_line = 1,
= 0,
= 0x0,
0x0,
0,
0x5555559a1e80,
Lab",
coor_version = {
{byte_order = 0,
"\000\001\002\003",
= 1,
1,
dig_fp = {
0x0,
0x0,
0x0,
0x0,
0},
0,
0x0,
SF_GEOMETRY,
0x0,
SF_GEOMETRY,
0}},
0}
-136416591,
32767,
140737353923672,
685899776,
"\001\000\000",
-4163,
32767,
              off_t_size = 1,
"\020\325\377\377",
32767,
1,
32767,
-10896,
-4163,
310,
-4163,
-136417169,
-136417169,
140737351874544,
140733193388033,
140737488344672,
140736985276032,
302,
0x7fffffffd7b4,
0x7fffe203c70d,
0x83a>,
-136431277,
310,
310},
-201740488,
140737340084280,
140737354101808,
2822930839,
= 120,
4160538376,
<__restore_rt>,
0x7ffff7fcbc58}},
head = {
address 0x13352e3>,
0},
"\377\177\000",
0,
last_offset = 21,
0x0,
0x1>,
0xffffffff,
1952531488,
-9320,
0x17>,
0x0,
1040,
1088,
                array_alloc = 64},
= 110}},
119}
        Centers = 0x0
        acentres = 0
        ncentres = 0
        apnts1 = 0
        apnts2 = 0
        pnts1 = 0x0
        pnts2 = 0x0
(gdb) l
141	in tavl.c
