[GRASS-user] Sentinel2 para procesar imágenes de Sentinel-2 MSI L1C a L2A
Eddison Araya eddisonjose at gmail.com
Thu Nov 17 05:31:01 PST 2016
Hola Stefan y Markus, muchas gracias por su respuesta
Saludos cordiales
Eddison
2016-11-17 1:51 GMT-06:00 Blumentrath, Stefan <Stefan.Blumentrath en nina.no>:
> Hei Eddision,
> Currently you will have to use a 3rd party solution for that (e.g.
> sen2cor).
> Please note that ESA is conducting a “Atmospheric Correction
> Inter-comparison Exercise” (ACIX) where the different available algorithms
> are benchmarked against each other: https://earth.esa.int/web/
> sppa/meetings-workshops/acix
> L2A products will become directly available from ESA in 2017.
> Cheers
> Stefan
> *From:* grass-user [mailto:grass-user-bounces en lists.osgeo.org] *On Behalf
> Of *Eddison Araya
> *Sent:* 17. november 2016 03:30
> *To:* GRASS user list <grass-user en lists.osgeo.org>
> *Subject:* [GRASS-user] Sentinel2 para procesar imágenes de Sentinel-2
> MSI L1C a L2A
> Hello, it's a pleasure to greet you, hoping you are well. Has anyone
> processed sentinel 2 images to convert from level to L1C to L2A? Thank
> you very much! Eddison
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161117/85833067/attachment.html>
