[GRASS-user] Question on memory allocation and use
Rich Shepard
rshepard at appl-ecosys.com
Sat Oct 1 05:42:49 PDT 2016
On Sat, 1 Oct 2016, Moritz Lennert wrote:
> FYI: In grass7, r.mask has a 'vector' parameter which allows you create a
> mask directly from a vector map.
Moritz,
I saw that and decided to try that today since I'm not having the results
I want.
> And AFAIK, no need to g.copy. Just run your analysis with the mask set
> (and the region also correctly set to only the area of interest).
To check my understanding: the project region has been set to Oregon North
NAD83 (HARM) with units of meters. I create the MASK using the analytical
boundary vector file, then set the computational region to that vector. Now
when I run r.contours with in=lidar_dem only those points within the MASK
will be converted to vector contours. Is this correct?
Thanks,
Rich
