[GRASS-user] map display query and layers
Dave Roberts
droberts at montana.edu
Sun Oct 2 10:12:27 PDT 2016
Thanks Moritz. This looks like the solution I was looking for.
However, I have not been successful at building GRASS from source for
quite a long time (just tried again and generated fatal errors in over
50 directories), so it will be a little while before I can test the
patch. At a first glance, much of it appears to be the use of a TAB in
python code causing indentation problems, but that is clearly a
different issue than v.what behavior.
The v.what Makefile has a few environment variables to sort out before I
can isolate just that program and substitute it in, so I will report on
test results as soon as I am able.
Thanks, Dave
On 10/02/16 06:23, Moritz Lennert wrote:
> On 02/10/16 10:53, Helmut Kudrnovsky wrote:
>> it seems that d.what.vect [1] reports always all data of all layers.
>> the same with v.what although the queried layer is specified.
>> so maybe a bug/enhancement ticket is needed.
> https://trac.osgeo.org/grass/ticket/3172
> I've attached a patch to v.what. Please test if this solves your problem.
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
