[GRASS-user] map display query and layers
Markus Neteler
neteler at osgeo.org
Mon Oct 3 14:18:59 PDT 2016
On Mon, Oct 3, 2016 at 7:12 PM, Dave Roberts <droberts at montana.edu> wrote:
> Hi Markus,
> Given your kind offer I elected to try and compile GRASS again. This
> time I was successful (after a few false starts). The primary problem was
> python confusion, where arch linux assumes python3 as the default, and I had
> not done the symbolic links correctly to redicrect to python2. After that
> ./configure \
> --without-freetype \
> --with-postgress \
> --with-readline
> worked successfully. I'm now testing GRASS-7.0.5.
Glad you solved it! Please verify if all here is ok:
https://grasswiki.osgeo.org/wiki/Compile_and_Install#Arch_Linux
Best,
Markus
