[GRASS-user] v.in.ascii: 6 points imported, 4 displayed
Helmut Kudrnovsky
hellik at web.de
Tue Oct 4 11:46:16 PDT 2016
Rich Shepard wrote
> Using v.in.ascii 6 points were imported but only 4 display on the map
> window. All 6 appear in the attribute table; when I right click on the
> each
> of the two invisible ones and select 'highlight selected feature and zoon'
> the symbol displays in a light yellow rather than the black of the 4
> visible
> points.
> Input data are:
> 1|-123.184|45.212|157|0.3E
> 2|-123.210|45.215|132|1.0WNW
> 3|-123.187|45.232|163|1.5N
> 4|-123.134|45.195|159|Airport
> 5|-123.204|45.211|137|0.6W
> 6|-123.270|45.240|458|4.3WNW
> and the command line is:
> v.in.ascii in=wx_stat.txt out=wx_stats x=2 y=3 z=4 cat=1 columns='cat int,
> x double precision, y double precision, z int, lable varchar(20)'
> --overwrite
> I am not seeing a problem with the data or command, nor do I see a
> potential explanation on the manual page.
> A clue stick is needed.
quick test here; just zoom out and you will see 6 points.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-ascii-6-points-imported-4-displayed-tp5289270p5289281.html
Sent from the Grass - Users mailing list archive at Nabble.com.
