[GRASS-user] [Ubuntu] python-grass code not working on ubuntu
Rich Shepard
rshepard at appl-ecosys.com
Wed Oct 5 10:28:04 PDT 2016
On Wed, 5 Oct 2016, alassane toure wrote:
> ERROR 1: gdal_translate was compiled against GDAL 2.1, but the current
> library version is 2.2
Alassane,
I don't know what distribution you run; regardless, the best solution is
to re-compile gdal on your machine (running version 2.2). You might need to
rummage around a bit to find the source code for your distribution/version
but then you can build it to fit your system.
Rich
