[GRASS-user] r.contour: levels vs step
Rich Shepard
rshepard at appl-ecosys.com
Fri Oct 7 13:58:46 PDT 2016
On Fri, 7 Oct 2016, Markus Neteler wrote:
> Well, yes and no: For a full example, it would also include a sentence
> describing what it is about plus the g.region command to set the
> computational region etc.
For an example of using levels with r.contour this example uses the
elevation map from the North Carolina database:
g.region raster=elevation
r.contour in=elevation out=contours levels=60,90,120,150 --o
d.mon wx0
d.rast elevation_shade
d.vect contours color=red
> To make the screenshot more attractive (about screenshot size and
> quality, see https://trac.osgeo.org/grass/wiki/Submitting/Docs#Images),
> we could include the shaded terrain as background:
I don't have pngng installed here; the attached image is scaled to 600 dpi
horizontal and propotional vertical density.
Rich
Type: image/png
Desc:
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161007/875a6cbe/attachment-0001.png>
