[GRASS-user] Layer management window questions
Vaclav Petras wenzeslaus at gmail.com
Mon Oct 10 11:56:07 PDT 2016
On Fri, Oct 7, 2016 at 10:41 AM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
>   1.)  When re-arranging the z-order of map layers why must only a lower
> level map be moved up and not also an upper level map moved down?
I think this is wxPython limitation. You can try it in the "wxPython demo"
and report it as bug at wxPython/wxWidgets bug tracker.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161010/8139848a/attachment.html>
